Results 1 to 6 of 6
Thread: 1998 engine swap
    Default 1998 engine swap
    Hi,
    I have a 1998 chevy cheyenne 2500 with a 6.5 turbo diesel (VIN# 1GCFC24S7WZ251336) and i'm trying to determine if the engine will fit in a 1998 chevy cheyenne 2500 4X4 with a 6.5 diesel (not sure if it's a turbo) with VIN# 1GCGK29F7WE231081; that i hope to purchase. According to www.decodethis.com, these engines have 2 different horsepower/torque rating which leads me to believe they're not the same engine. My question is are they the same engine (perhaps www.decodethis.com is not reliable/accurate) and are they interchangeable? According to some research i've done online, there are 2 to 4 different types of engines that could possibly be in my truck (VIN codes F, S, M, or J). I'm not sure if I have the "F" or "S" because I don't know which digit to look at in the vin #...can someone please help me? Thank you.
    Apr 2006
    Cedar Grove, NC
    7th digit.
    Jul 2005
    IL
    Smile
    The basic power plant is the same, block, crank, piston. rods ect. the intake will can be different, from a heavy duty to a light duty(will have EGR) and computer programing again all the hard parts with exception of intake they are identical hope this helps good luck
    Welcome to the Forums!
    8th digit. F is HD, and S is LD. Your truck was OEM a LD (7200 GVWR), with EGR and less power than the HD engine (8600+ GVWR) you are looking to purchase, and it will have/had a turbo. The engines are identical, underneath the EPA stuff and programming.
    Default Thank you everyone.
    thanks for the clarification - that really helps!
    Apr 2002
    PA
    7th digit in VIN is for the cab configuration. 4 is a regular cab, 9 is an extended cab...
    1994 K1500 Blazer: 6.5L TD/4L80E: 'F' intake: Kennedy chip: Kennedy 3.5" exhaust: Heath Turbo-Master: 2/0 battery cables: Lubrication Specialist oil cooler lines: Fumoto drain valve: Amsoil dual bypass remote oil filter kit: Fluidampr: 137k miles
