Results 1 to 9 of 9
Thread: bigger radiator?
    Sep 2007
    Sweden Dalsland
    Default bigger radiator?
    Hello!
    can i use my gas rad to my 6.2 converson
    GMC 89- sportside
    Aug 2000
    Riverside, CA USA
    Is the gas engine the 350 or 454? The 454 radiator might be similar to the 6.2, but the 350 is probably to small.
    83 C10 Suburban, Silverado, 6.2, 700R4, 3.73, 31-10.50R15
    82 C30 Crew Cab dually, 6.2, Banks, Th400, 4.10, Gear Vendors, 235-85R16
    83 C20 Suburban, Sierra Classic, 6.2, 700R4, 4.10, custom paint, 285-50R20
    95 Yukon, 6.5, 4L80E, 3.42, 265-50R20
    73 GMC Astro 95, 8V71, 10 speed Roadranger, 110" WB, 6 each 11R24.5
    Sep 2007
    Sweden Dalsland
    It´s for the 350
    but i dont understand this i thougt gas engines produced more heat
    Thank you for your reply
    Quote Originally Posted by conan View Post
    Nope!
    Just to start out, 6.5L is about 396 cubic inches, so about 13% greater than your 350. Also depends on how hard you work it.
    Diesel Page Member #2423
    Aug 2000
    Riverside, CA USA
    You will want to get a 6.2 radiator. The higher compression ratios of the diesels generate both more power and more heat.
    Sep 2007
    Sweden Dalsland
    Is the banks turbo watercooled?
    do you think i shuld bye and install banks before i install the engine in the truck or is it best to see so the engine vorks well in the truck?
    sorry for my bad english
    Chevy C2500 95- 6,5 TD
    Welcome to the Forums, Conan!
    You are getting sound advice here. A small block radiator will be a liability.
    The Banks turbo is not water cooled.
    Sep 2003
    Feeniks, Aridzona
    Due to the design of the front clip of my Waggy, I was limited to the size that came with the 360 gasser. I installed a 2 core aluminum replacement and have not had any cooling issues. BUT...if I had the room I definitely would have installed something bigger. Since a diesel was an option in your chassis, I would install the bigger radiator.
    No one ever regretted installing a bigger radiator.
    Aug 2000
    Riverside, CA USA
    The Banks kit can be installed with the engine in place. Right side exhaust manifold has to be removed and replaced with the Banks unit. The Banks kit would be easier with the engine out of the truck, but either option will work.
