Results 1 to 15 of 15
Thread: Hard-shifting 4L80E
    Mar 2004
    Norway
    Default Hard-shifting 4L80E
    Hi all, have a problem with the transmission in my -91 burb. Started a couple of weeks ago with harsh shifts from 1. to 2. gear. Rpm was also higher than normal when it banged into second gear and lock-up was`nt engageing when it should. Then suddenly everything went back to normal with smooth shifts. But of course, troubles came back and today it was almost impossible to get the lock-up engaged. Transfluid and filter are about 10000 miles old, on the mark and nice color. I think (hope) its a electrical problem, what do you guys think? Solenoid in the pan? Tps?
    Trond
    Didn't reallize they used the 4L80E on the '91s...
    Could be the TV switch. Check for codes, too.
    Mar 2004
    Norway
    Hi John, this tranmission was introduced in -91 behind 6.2- and 454-engines.
    About the TV-switch, is this short for trottlevalve switch? Is this in any way connected with the TV-cable? If thats so I`am not sure if I have a TV-cable on my transmission. Correct me if I`am wrong.
    Trond
    Apr 2004
    Palm Beach, Florida
    Default Trouble shooting 4L80
    I'm thinking the 4L80 transmission is hard to come by in your area it maybe a good idea to get tech manuals and parts for it, see attached link. http://www.transmissionspecialty.com/
    The euro's strength can get you a good deal on an imported unit from North America if you decide to go this way make sure you get 1999 or later unit as it will have all the updates to correct problems associated with older units like you have.
    What series of truck, 1500, 2500 ? which engine?
    Does the tranny have a cable coming from the case near the dipstick tube?
    Robyn
    Mar 2004
    Norway
    Hi, my truck is a 2500 series with a 6.2 diesel. And yes Robyn, a cable is comming up near the dipstick tube with wires to the TPS and some to the IP.
    Trond
    If it has a cable up by the dipstick then your truck has a 700R4 tranny and not a 4L80
    The 700 pan is almost square and will have a small square electrical plug on the LH side of the pan rail about midway back.
    The hard shifting is most likely a throttle pressure issue.
    Check the cable where it connects to the IP and be sure it moves freely.
    If the cable has become stuck it will cause hard shifts at light throttle.
    Let us know what you find
    Mar 2004
    Norway
    Hi Robyn, I guess I should know better than arguing with you, but I`ll give it a shot. When you asked about the cable by the dipstick tube I thought you ment elecrical wires. My technical English is not that good. There is a plastictube, about 1 inch in diam. comming up by the tube, it is black and have a bunch of wires inside. My pan have 17 bolts and when I change transfluid and filter I replace it with a 4L80E filter. There is no cable attatched to the transcase, only two places where electric wires are connected. One of these is covered with a plastic shield with a torxscrew in the middle. I hope this will convince you.
    Trond
    OK then you do have a 4L80
    During this time frame the 6.2 could have been installed in a light duty 2500 with a 700R
    Can you scan the ECM to see if there are any codes?
    The next thing to check is to be sure the TPS is working correctly. If the TPS is giving a bad reading it can cause the harsh shifts..
    let us know
    Good luck
    Mar 2004
    Norway
    Hi all, just scanned for codes. Got me a 85 and 86. Am I in big trouble or is it just some sensors? What does it mean: "TCC is mechanically stuck on" ?
    85 Programmable Read Only Memory error or undefined
    gear ratio (input or output sensor failure)
    Torque converter clutch (TCC) - TCC is mechanically
    stuck on
    86 Analogue/Digital Electronic Control Module (ECM)
    error or shift Solenoid "B" stuck on
    Trond
    Mar 2004
    Norway
    Hi all, is it absolutely certain that the TPS will throw a code if its broken?
    Trond
    The TPS has 3 redundant circuits. The PCM monitors all 3 for agreement. I can't conceive of a failure mode that would not set at least one code.
    The APP is the skinny pedal module. The TPS is the switch on the side of the IP. The 91 has a TPS, and 1994+ has an APP (no mechanical IP input).
    (oops!)
    My comments refer to the APP, not the TPS.
  15. #15
    Mar 2004
    Norway
    Angry
    Hi folks, changed shiftsolenoids today but no improvement. And still getting code 85 and 86.
    No code for the TPS.
    Trond
