Proportioning valve?
I think you are right, the proportioning valve is closer to the master cylinder.The block you are refering to is pretty much just a T fitting that the brake supply lines fit into ,to supply the rear brake cylinder's. Doesn't it have 3 brake lines in it? Mine sprang a leak on it and it was just a wheel cylinder line. Just clean it off so you can see wich line is leaking and replace the line. Advance auto has lots of diferent sizes
