lots of play in the column
On my 84 when shifting into gear there is a lot of play in the column between gears and even when in park. You can move the shifter a couple of inches without going into gear or switching gears. Yesterday I noticed when parked slightly uphill the shifter would slip out of park unless i threw it in park fast. On flat ground its fine and feels like it goes in no problem. Any way to get rid of the slop or what the cause would be??? Or should I go to the junkyard and take out another column??
1984 K2500 6.2 AOD
2001 Dodge Cummins
Too many Mustangs
