Results 1 to 4 of 4
Thread: Used Motor Oil as Pump Lube
    Nov 2005
    Brady, Republic of Texas
    Default Used Motor Oil as Pump Lube
    All,
    I've read posts from my esteemed colleagues here somewhere (could not find in numerous searches) who are using used motor oil in the diesel as DIJ pump lube. I tried this in the fleet last week and was simply amazed how much quieter and smoother both are now idling. The Tahoe is also starting faster.
    My question for those doing this: what method are you using to filter the used motor oil?
    This batch I used was simply double settled, that is settled in the catch tank, then the top portion poured into a second clean tank and settled again and then the top of the 2nd tank captured for the pouring into the tank. I think the month of each settling time shook down most of the contaminants but I envision a strainer/colander with a home-made giant paper-towel as coffee filter inside the colander might be my 'polishing' filter. But, I rely on you folks heavily so as not to reinvent a process someone has already refined.
    Thanks and Happy A.D. 2008
    Mark Magee
    98 Burb 2500 LT 4x4 VIN G, 4:10's 180K miles, Amsoil Bypass/full flow filters, Turbo Master, Heath ECU Reflash, Duraterm GP's, New Injectors, Walbro FRC-13 LP, 480LE Rebuilt 2X, Vacuum Pump Delete, K&N Filter, Fluid Damper, DTech remote bumper mount PMD, Kennedy Exhaust, Kennedy Fan Clutch, Robertshaw 192F stats, 2.5" Crossover, CAT gutted, Fumoto Drain, Alcoa Centerline Wheels, Ride Rite Airbags.
    2013 Keyston Fuzion 301 Toyhauler 9,100#s empty
    Velocity XLFG N34XL
    Brady Texas Hill Country
    Hi
    I remember a filter system my dad had made for cleaning used engin oil,it was two 10 gal drums on top of each other,the top one had about 4 layers of gyprock in it on or nearthe bottom with a hole in the drum letting the oil seep into the bottom drum,i don't remember how long it took to seep thru,the bottom drum had a valve about 3" from the bottom.He used the oil in all the yard beaters we had,i used it in my bush buggy,i remeber it was allways clear and clean.The oil came mostly from the gen sets we had for power,we lived 35miles from the grid,135 miles from the city so thier was a lot of recyling done living in the bush,nothing was thrown away till it was of no use whatsoever.
    Oct 2005
    Boise, ID
    Check out this link http://www.utahbiodieselsupply.com/filters.php. These are 55 gal drum filters. The finest filtration is 100 microns so I'm not sure that is enough but a little modification could add some filtration. Personally I'm not so sure that I would use engine oil in the fuel. I would think that you would get large amounts of carbon buildup. I know what the inside of a gasser looks like after 50k miles with leaking valve seals. Hope this helps.
    94 2500 4x4 Suburban (Stock).......but not for long.=)
    The cost of cleaning used oil (diesel fuel filters aren't cheap) has been the biggest drawback to using used motor oil as a fuel extender. Secondarily, corrosive compounds can accumulate in motor oil that cannot be removed by filtration. As a result, used motor oil is considered hazardous waste by the EPA.
    For most, the cost of diesel fuel filters outweighs the cost savings of using used oil. However, there is a filter design that uses centrifugal force to remove particles down to the sub micron size. One example of these can be found at the following link:
    http://www.ipfonline.com/storefront/...p?ProdCode=797
    Once acquired, a centrifugal filter offers the advantage of no-cost filter element replacement (because there isn't one) for the life of the equipment. The one linked above is advertised at removing down to 0.1 micron size particles.
