TheDieselPage.com Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > 6.5L Turbo Diesel
6.5L Turbo Diesel 1992-00 6.5TD - Discussion forum for the 6.5L engine.
Reply
Thread Tools Display Modes
  #1
Old 12-24-2007, 05:58 AM
nextlevel nextlevel is offline
Newbie
Unhappy PMD problems
I have a 1995 c2500 6.5L. I have replaced the PMD 3 times in the past 3 years. Is there another solution for this part? It is very expensive.
James
  #2
Old 12-24-2007, 07:42 AM
Robyn's Avatar
Robyn Robyn is offline
Missy Good Wench ( Moderator)
The best solution we have to date is to mount the PMD on a good remote mounted cooler outside of the engine bay.
Extention cables available from various aftermarket sources up to 6 ft long.
Dtech now offers a replacement PMD for a fairly decent price. I paid $279 for mine IIRC
I installed one of these on my 95 DaHooooley earlier this fall when I was having some issues with it. Turned out to be another little problem but there were no codes and anytime the engine cuts out the PMD can be a suspect as far as Im concerned, at least when other obvious things are eliminated first.
The DTECH PMD looks just like a factory unit except it is a little thicker.
The key is remote mount it where it stays cool/Cooler than under the hood..
Another issue can possibly be poor grounds on the battery cables as well as the psitive cables too. An alternator thats starting to toss alternating current rather than DC can louse things up too.
Be sure your engine and body grounds at the rear of the engine Intake manifold RH side are clean and tight.
14v+ should be seen at the power box feed with the engine idleing.
The sensitive micro electronics on these trucks needs to see good clean voltage.
If the cables are going south and the voltage is dropping off then the amperage draws can climb. If there are ground issues this can seriously effect the electronics as when the grounds go sour all sorts of wierd crap can happen including damaging sensitive circuits.
Another seldom taked about subject is that whenever a rig has some welding done on it, such as a hitch or ???? the batteries should be disconnected.
Check these things out as well as remote your PMD
Hope this answers your ?????????
Happy Hollidays
__________________
(1) 95 Suburban 2500 4x4
(1) 2017 Mercedes C class
(1) 1997 Astro "CATVAN II"
  #3
Old 12-25-2007, 06:54 AM
CapnAmerica's Avatar
CapnAmerica CapnAmerica is offline
Newbie.
Default More PMD Thoughts
This subject always stirs up comment...
I bought a 4-foot extension with finned cooler, removed the cover over the power transistors, used Bellville-spring washers (supplied by that vendor) to mount PMD to cooler, used the supplied heat-transfer goop, and moved the PMD to the bracket with the ABS controller on it--handy threaded holes there . Then I had another failure . This time I moved the whole thing to the hole in front of the driver-side battery, and mounted a fan in front of it.
To date, no failures!
Info on the fan: Radio Shack item #002763154, 120x25 mm...still running at last check. It was a trial to check life, because this is quite a bit more severe duty than sitting in a case on the floor of the house! I have the fan running at high speed (it's adjustable) whenever the ignition is on.
Good points, Robyn, on the voltage, and on welding. I would go a notch more conservative on welding issues, though, because in my former life as a maintenance manager, I saw some suspicious things happen on equipment on which we welded. The stray and induced currents on the structure being welded aren't at all predictable, and damage can occur which goes undetected while allowing function of the part, but later causes a "mysterious" failure. So I would unplug the PMD when welding is being done...come to think of it, maybe one of MY failures happened after I welded up my 4" exhaust!!!
Also, get rid of the side-post batteries...they will at some point, if you keep the truck long enough, seep acid through the internal seal and make your connectors disappear while never showing any problem outside the little plastic cover. (It's nice to be able to make a firm connection if you want to jump another vehicle from...or TO...yours.)
AND...don't forget to remove the %*&$^*@ TURBO POWER plastic cover, even if you also move the PMD. Trapping the heat and inhibiting air movement ANYWHERE around the injection pump can't be good for the fuel-supplied lubrication of the injection pump. (Not to mention its former duty in trapping heat to help roast the PMD!?!?!?)
¡Buena suerte! Good luck!
  #4
Old 12-25-2007, 11:01 AM
Robyn's Avatar
YUPPPPPPPPPP as far from the heavy heat as is possible.
The PMD is not nearly as vulnerable to the stray currents as is the Computer/ ECM-PCM
Disconnecting the battery cables will "Usually" stop any issues as there is not a completed path for the flow of these stray voltages.
If the gounds are not connected then in theory there would be no path for the influx of current.
The class 8 trucks have stickers all over them as to this very subject due to the many and varied upfits this stuff sees when being outfited to do specific jobs (Dump trucks, cranes ect)
The removal of heat from the PMD is the one proven thing that does enhance the little black box's life span.
I am very excited to now see that there is another player in the PMD arena.
With Dtech making a replacement we at least have a somewhat lesser expensive choice.
I am running one now so we shall see.
I run the dual post Optima jello batteries and have had very good luck with them to date on all my rigs.
The big truck gets top threaded terminal commercial batteries and they are ok.
Yup the cables just go away inside and still look great
Been mugged there a few times earlier in my life.
best
__________________
  #5
Old 01-10-2008, 06:31 PM
Jim Faire Jim Faire is offline
Enthusiast
Personally, I figure if your truck has eaten 3 PMDs in 3 years, you should be thinking about buying one with a warranty.
The Heath PMD Isolator (reviewed on this forum) has a 7-yr warranty and mounts outside the engine bay.
Half of the issues with home-brew solutions include wiring, flat surfacing on the heat-sinks, improper thermal transfer application, poor electrical work or grounding issues, and finally not doing the calculations on mass/suirface area of the heat sink for thermal balance.
Why tell somebody that's already bought 3 PMDs to try again?
It's not like the worst that will happen is it might not start... stalling in traffic with a load on is scary (steering/brakes/hydroboost), or when merging, or just plain dying out in the boonies somewhere (it IS winter, ya know). Peace of mind is priceless.
Phone Heath Diesel or USDieselparts and solve your problem for 7 years.
JMHO
__________________
Real Trucks Don\'t Have Spark Plugs
  #6
Old 01-10-2008, 06:42 PM
Robyn's Avatar
I have seen several failures of electrical stuff after rigs have been to the exhaust shops.
All it takes is a little wild and wooly fluxing of current induced into some little electronic component to set the failure in motion.
An old friend of mine installed hitches for years and did a job on a Reeeeeeeeeealy high $$$$ Mercedes and after he finished the hitch the rig would not run
He called me and I advised him to disconnect ther batteries and wait about 10 minutes and then hook it back up.
Seems that the Mercedes has some sort of circuit protection system????
It ran fine afterwards and the rig was a local one.
Enough to make one shudder though at the thought.
__________________
  #7
Old 01-11-2008, 07:17 AM
Enthusiast
More likely, it was the RF flux affecting the Engine Immobilization system, Robyn. They can be re-set with a battery disconnect, too.
It's highly unlikely that you're gonna damage electronic components with EM flux - unless you attach a ground clamp to the electronics, rather than the frame or exhaust pipe.
__________________
  #8
Old 01-14-2008, 12:25 PM
Iain's Avatar
Iain Iain is offline
Enthusiast
Smile
Definity re-mount it away from teh pump to a better, more cooler spot. The mounting on the pump is a heat trap. I had my pump changed on warrenty (3rd one) just prior to the warrenty expiring (193,000 km I believe it is). I remounted the PMD and now have 350,000 km on this last pump with only one change of the PMD. The old one was still good but I am a cautious fella and wanted a good used spare anyways!
I know I will get some arguement back on this, but I did mount mine on top of the intake with an FSD Cooler. I realize this is not the best spot, but as the colder weather up here helps keep the engine temp down and the Duramax fan I use seems to pull a lot of air over the engine, it works for me! As well, I do very limited towing so I do not pull the heavy loads that other members do.
My 2 cents or so......
Iain
__________________
1994 GMC light duty 3/4 ton 4x4 w/ 6.5L TD 3.73 gears, FSD Cooler, DSG Oil Cooler, 97 Cooling upgrades, 21" Duramax Fan, Kenneday Fuel Pump Kit, 3" Mandrel Bent Turbo Down Pipe, Marine glow plug timer, Boost and pyro gauges.
  #9
Old 01-14-2008, 12:46 PM
Enthusiast
I'm not gonna argue with you, Iain, but since I've been stuck on Deerfoot or Macleod before too, how about you try this:
Get yerself one of those remote-mount bbq thermometers at Canadian Tire. Put the probe under the hood, say, next to the PMD. Put the readout inside the cab.
http://www.canadiantire.ca/browse/pr...08474396672586
Next time you find yourself sitting still on a 90*F Calgary day, check the thermometer. Your DMax fan doesn't help too much with that, and after you shut ioff the truck, the temp will continue to climb for about half an hour. It's called 'Heat Soak', and having cold winters doesn't fix that in the summer.
If you're surprised by the temperature you find, try different places under the hood... you might be surprised to find that mounting it above the intake manifold is just about the hottest spot in the engine compartment.
Sure am glad it's working out for you so far, though! PMDs are a pain in the butt.
There. My .02+gst.
Iain
__________________
  #10
Old 01-14-2008, 01:00 PM
Iain's Avatar
Enthusiast
Hmmm, good point Jim. Seeing as you am from Calgary as well, where did you mount yours? I do drive in the bush some so I want it out of the snow and mud.
Iain
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
