Made in CHINA 6.5td dual thermostats
Ran into a problem with 6 month old thermostats sticking open.
Pull em out and find the (big) back gaskets (on stat body) on both of them somehow managed to get pushed into and stuck between the thermostat valve and its body.
Most obvious is "MADE IN CHINA" stamped on em.
