This is of no direct help, but may be of some use in troubleshooting. The HVAC fan's speed is adjusted by way of resistors, individually selected by the speed selector. Typically, these are in the ground circuit ("hot" being supplied by the relay). Ground from the fan motor is routed to chassis ground through one of the resistors (except none for the highest speed). Although my motorhome had an OEM GM engine, the HVAC system is Chrysler...(headlights are Cadillac, and the radiator surge tank is Ford...the RV that Topsy built ...)
Does the fan work if the ground wire is disconnected? If so, that would indicate a short to ground somewhere. Also check the fan operation with A/C on; there's a (very) remote possibility that there's something awry with the A/C compressor clutch wires.
