Results 1 to 4 of 4
Thread: 73-87 Diesel Warning Lamps
    May 2004
    Cincinnati
    Default 73-87 Diesel Warning Lamps
    I am presently working on the wiring etc to install a 6.5 NA engine in my 76 K20 Silverado.
    I'm replacing the 76 mechanical oil pressure cluster with a 78 that has an electric pressure gauge and a Tach. The Tach and Speedometer each have 2 warning lamp positions at the bottom rather than the single "BRAKE" lamp in the 76 cluster...
    BRAKE is a must keep... I would like to put both diesel specific lamps in the cluster and keep the 4x4 indicator.
    In the 82+ 6.2l rigs where are the "water in fuel" and "wait to start" lamps located?
    Jul 2006
    Fort St. John BC Ca
    External to cluster--in bezel. Two 1/2in squares of red.
    1985 K1500-sold
    79 dually 4x4-soon to have modified 6.2/6.5l turbo
    1996 shortbox-extended cab 2WD 1500 6.5L
    May 2004
    Cincinnati
    Are they all there or just the medium duty C40-80 trucks?
    All of them. WIF is red, GP is amber.
