Results 1 to 6 of 6
Thread: 94 Heater/AC Fan 'Banging/Thumping' Noise?
    Brighton, CO, USA
    Question 94 Heater/AC Fan 'Banging/Thumping' Noise?
    A coworker has a 94 GMC 6.5 that makes a peculiar thumping or banging noise near the fan/box assembly under the dash.
    What's weird is that it only does it for about 10 secs after the key is turned on and then also does it for about 10 secs after the key is turned off.
    After the banging episode ends (key on), all the ac/heater control functions work fine, all fan speeds work, and no strange noises - just during power up and down.
    Maybe one of the control doors is trying to open or close, or the fan is running on its own against a closed door? Switching the fan to off before shut down makes no difference.
    Any thoughts? Weird.
    Thanks.
    Joe.
    2006 Chevy K2500 LLY Duramax/Allison Crew Cab!
    1996 Chevy C2500 6.5 auto Ext. Cab LB
    May 2000
    Little Neck,NY,USA
    The truck has a bad recirculation door motor, with ignition off the motor is trying to find home position.
    Quick fix is to unplug the motor, to replace the motor GM says you need to roll the dash back.
    I have replaced those motors without rolling the dash by using a 1/4 inch air rachet and a 5.5mm snap-on flexsocket and guessing where one of the screwhead is because you can't see it.
    William
    97 Chevy Tahoe 2Dr 6.5 Kennedy Exhaust Pipes w/Homemade Resonator and Flowmaster Muffler, Turbo Tech intercooler and Kennedy/Westers computer
    01 Sunline 2363 Travel Trailer
    Brighton, CO, USA
    Thanks. I figured it was something like that.
    Can you guide me to the motor/connector location for unplugging?
    May 2000
    Little Neck,NY,USA
    Looking up under the dash on the passenger side and imagine the blower motor is a clock, it would roughly be in the 9:00 position, close to the firewall.
    It is a small three wire connector, the motor is about the size of a pack of smokes.
    William
    Brighton, CO, USA
    Okay, thanks. We'll give that a shot.
    My 94 has done the same thing.
    I set the thing for recirc in the summer and then back to outside air in the winter.
    I have not tried to ferret the thing out yet but as is mentioned it is doable with a little patience and some time.
    The recirc door motor runs until it stalls then once the motor stalls, the current load causes the contoler to shut it off.
    The other door motors have a specific home feature.
    The recirc motor gear box has plastic parts and they wear out. the gears slip and then there is not enough current draw to cause the contoler to shut it off so it goes thunk thunk thunk thunk.
    Best
