Originally Posted by
CareyWeber
I'd bet you'll have rubbing issues with 285s. I have 265s and they will rub a certain times. You tow so that will most likely increase the rubbing chances.
Carey
Every truck must be a little different. I have 265's on my K1500, and I've never rubbed at all. I'm considering going to 285's as well, mostly for looks!
