Results 1 to 9 of 9
Thread: 6.5 Auto to ZF 6 Man. Trans. Conversion?
    Brighton, CO, USA
    Default 6.5 Auto to ZF 6 Man. Trans. Conversion?
    I'm contemplating a trans. swap on my 2000 6.5 1ton - I miss the 5-spd manual on my 98, felt it pulled better than the auto. The main drawback with it (the auto also) was the wider gear splits, hence my thinking of a ZF 6-spd manual that would offer more ratios.
    I'm not sure if anyone has done this, but:
    I understand the GM ZF 6 spd. manual trans. used with 8.1 and Dmax should bolt right up to the 6.5, bellhousing wise?
    Does anyone know if the input shaft for the ZF is different than the NV4500 5-spd that was used with the 6.5?
    I'm assuming I could use a clutch for the 6.5?
    Would the ZF physically fit - I'm guessing it's smaller than an allison?
    Would it bolt up to my BW 4401 transfer case or would I have to use a newer t.case from a Dmax/8.1?
    Thanks in advance.
    Joe.
    2006 Chevy K2500 LLY Duramax/Allison Crew Cab!
    1996 Chevy C2500 6.5 auto Ext. Cab LB
    Knoxville,Tennessee
    I nosed around last year trying to do the same thing. I kept getting the comparison to "Hens Teeth". Never did quite figure that on out.
    If you have lots of $$$$$$$$$$$ you can get a rebuilt and pay the price for the core. . . . . http://drivetrain.com has a lot of choices and parts as well as service and advice. Not many GM 6 speeds available. Don't know how much it would take to get a ford or dodge to work.
    But if you find something, don't keep it a secret!
    -Patrick Henry
    A5150nut
    2006 K3500 D/A
    94 6.5 4x4 5spd Sold
    Is the NV5600 a closer match than the ZF? Not sure they were ever offered in the GM vehicles.
    Diesel Page Member #2423
    Brighton, CO, USA
    My limited research indicates the NV5600 won't work without a lot more adapting - the bellhousing is only set up for Dodge/Cummins as they were only offered with a Dodge.
    Likewise, the Ford ZF has a different bellhousing than the GM - the bellhousing is integral to the trans body.
    So it would seem the GM ZF would be easier, but I'm sure crossmembers and driveshafts would need to be changed.
    This may be beyond my shadetree capablities...we'll see.
    Thanks.
    Joe.
    Ah. Somewhere I thought I had heard that the NV5600 bolt pattern was the same as the NV4500 so you could use a NV4500 bellhousing.
    Knoxville,Tennessee
    NV5600 will fit with modifications. IIRC, it's 3 inches longer. Two drive shafts to shorten, lenghthen, and one cross member to move. Then back to the original problem, hens teeth.
    -Patrick Henry
    A5150nut
    2006 K3500 D/A
    Brighton, CO, USA
    Supposedly salvage yards have a couple ZFs and several NV5600s in my area. The NV's are pretty pricey -$2,200-2600.
    I thought I also read that another problem with the NV is the input shaft being different for Dodge. I think even the NV4500s are different in GM versus Dodge.
    Also, the ZF is supposed to be quite a bit lighter (weight wise) than the 5600.
    Knoxville,Tennessee
    Quote Originally Posted by joed View Post
    You can change the input shaft. IIRC, mine was about $83.00. The rest of the parts are the same, sept out put shaft.
    -Patrick Henry
    A5150nut
    2006 K3500 D/A
    Jan 2009
    frostburg md.
    i'm new to the 6.5 so i'm not sure but with a gas motor the computer is different also when ordering an aftermarket computer they ask man. or auto trans just something to think about
