Turbo Boost Bolt from www.pmdcable.com
Turbo Boost Bolts, engine oil cooler kits and lots of 6.5 turbo diesel parts. Check out the web site.
www.pmdcable.com
Sweet and simple YEEEEEEEEEESSSSSSSSSSSSSSS
Thanks Robyn.
I was thinking about giving a Turbo Boost Bolt away to a member here. The only condition is I would ask that member to post back on the forum a review of the item. Good or bad, pros and cons, pic's of the install ect.......
Robyn, since you replied I will give you first shot. Interested?
www.pmdcable.com
