![Quote](images/misc/quote_icon.png)
Originally Posted by
Redhanded
OK, Today I bypassed my filter assembelly, I made a gravity feed straight into the outlet hose of the filter housing. Truck did start without gas or either help but I had to crank it over for a few minutes for it to start even after system was reprimed from opening to attach my hose setup. So does anyone have any ideas, I'm thinking that the injector pump is starting to fall and not making enough suction or pressure to start it's self...
Could be the pump however hard starting is also a symptom of injector failure (high return rates) that could qualify for the 200Kmi/7 year Injector special policy ... http://www.thedieselpage.com/duramax...orwarranty.htm
(If you take it to the dealer I wouldn't tell them you bypassed the fuel filter)
Bill
98 K3500 6.5,SOLD
