Thread: Any one put a Cummins 6bt into a 91 GMC?
    Dec 2008
    Default Any one put a Cummins 6bt into a 91 GMC?
    Im wondering if any one has seen or heard of any one putting a 6bt into a 91 GMC with a 4L80E tranny.
    Its been done.
    A local fellow does a lot of 4BT swaps into the GM trucks.
    The 4L80 does not seem to do well with these engines and the trick fix seems to be to use the 47RH mopar tranny with its own Tcase
    I have seen this on mid 90's Burbs and it works well.
    Best
    Burning Oil's Avatar
    Burning Oil is offline http://www.lubedealer.com/pmdcable/home.aspx
    Jul 2006
    Houston TX
    Default Here is mine
    Its a 96,
    Turbo Boost Bolts, engine oil cooler kits and lots of 6.5 turbo diesel parts. Check out the web site
    www.pmdcable.com
