Originally Posted by
opto
you would be better off with some auxiliary lights pointing right and left a little
That's what I was thinking. Just put a set of aftermarket driving lights on their own switch. The bottom of the front bumper has some nice holes that you can use as mounting points. If their light pattern doesn't spread out as much as you think, just angle them a bit. This way you can still use your highs/lows as normal. A set of $35 lights from Autozone has been working fine for me - about 2 years, now.
