I am looking at replacing the shocks on my suburban. What options do I have? I've had good experience with bilstein on other vehicles. Is that a good choice?
Matthew
1998 GMC 6.5TD Suburban 3/4 ton 8600 lb gvw
Arlington, VA
IMO, that's the only choice. It'll be the HD ones. By the way, Kennedy Diesel (a supporting vendor here) carries them - and knows exactly the model you need.
has anyone used the rancho RS9000XL adjustable shock?
Matthew
Arlington, VA
