Remove the actuator on the turbo to see that the actuator moves properly not binding and has no excessive play pulling the flat part towards you.
Check for exhaust leaks, especially on the turbo crossover pipe, a blown donut can cause these issues.
Speaking of leaks, check for intake leaks as well, especially the boot between the turbo and the upper intake manifold. Then check the gasket between the upper and lower intake manifold, these can blow out.
J
1986 C10 SCLWB 6.2TD 3.73 700
1989 V20 SUB 6.2NA, 3.73 400
1994 G20 VAN 6.5NA, 3.42 60E
1996 K30 DRW 6.5TD 4.10 80E
