Well today was a productive day. Got the engine and tranny back in the BURB, installed the front diff, transfer case, and the front driveshaft. Got em all in and tightened down and most of the accesories on it as well and filled the front diff, engine, transfer case, and tranny up with fluids. My next BIG project will be wiring followed by installing my intercooler, then installing a 1/2" feed line from the tank up to where ever I mount the lift pump at, and then swapping out the rear gears to 3.42's. I also called up ALLIGATOR PERFORMANCE and ordered a CORSA muffler, DIAMOND EYE 4" SUBURBAN exhaust, and an AFE stage 1 intake. My EFILIVE came in last FRIDAY as well as a new 1410 series yoke for my 14 bolt. Hopefully my TCM gets back from Brayden here soon as I will need it once the wiring is finished up.
And now for some pictures.
The engine bay with the new sound pad installed.
And later on in the day it all came together.
It's a TIGHT fit, but you can just get to the fill plug to fill her up with fluid. I did have to grind alot of the ribs off of the extension housing though to get clearance on the torsion bar crossmember.
And the 01 front driveshaft dropped right in and fit perfectly. You can see in the pic though that the shift lever for the transfer case is just barely missing the tranny, so I will have to grind part of the transmission mounting boss off to clear it.
