My dash lights and gauges stop working when you turn on the headlamps. Hit a bump and they start to work and then out again. I have taken this thing apart 2 times and can not find anything loose. Ideas?
Lonnie Diers Extreme Automatics
1994 Chev 2500HD 532,119 miles 21,300 GCW towing machine.
Original engine, injectors, replaced head gasket 1 injection pump, 3 turbos
Ready to install ( was ready now changing to 18.1 pistons)
New engine 4 bolt splayed steel caps
Lightly ported heads
Polished intake port matched
HX35W Turbo
Intercooler (very efficient tube fin design)
Marine Injectors hi pop
Cooling upgrades
3" DP
4"exhaust
remote mount PMD cooler
Fresh air intake (in the making)
Gears ???? have not decided looks like 3.42
250HP at the wheels or bust (maybe both)
Bad headlight switch or connector. Mine does the same thing. I now have it hanging out so I can push the connector tighter to the switch when the lights won't come on.
1997 GMC Savana - 6.5 TD
1967 Jeepster - Stock
1986 Jeep CJ7 - Stock
Maybe a bad ground in the instrument cluster - Energizing the lights lifts the ground up enough to keep the gauges from working...
I am going to try a new headlight switch tomorrow. I have had the dash apart many times.
HX35W Turbo
Cooling upgrades
3" DP
4"exhaust
