Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: Transmission fluid
  1. #21
    Oct 2006
    North Pole Alaska
    Default 2006 and newer
    Require Dex VI, I use the AMSOIL. No problems, actually shift's smoother. The Dex VI gells at -20 and colder
    2006 Chevrolet Silverado 2500 HD
    Duramax LBZ, 6-Speed Automatic 4X4
    Edge Juice w/Attitude, S&B Air Intake, MBRP Cool Duals (turbo back)
  2. #22
    I too use Amsoil and it does a great job. Like others have said smoother shifts and a quality oil for the temps that mine indures in the deserts towing my toybox each summer.
    [CENTER]2005 Silverado 4X4 CC LB LLY [/CENTER]
    [CENTER]Air Lift Bags, [COLOR=black]Amsoil F2B[/COLOR], KB IOH Kit, BD Manifold, Fumoto Valve, PCV Reroute, Resonator Plugged, Mag-Hytec Diff Cover & Trans Pan, PPE X STD, 4" SS Magnaflow Kitty Ran Off[/CENTER]
    [CENTER][URL="http://www.duramaxfilters.com"]www.duramaxfilters.com[/URL][/CENTER]
  3. #23
    Jan 2010
    GREELEY COLORADO
    I have a built DTT tranny and i use the amsoil Torque drive not the atf is that a problem? What grade of oil do you guys run? 15 40
  4. #24
    Default what kind?
    Does anyone know what trans fluid comes in the 06 allison from the factory?? Is it dexronIII or dexron VI ??
  5. #25
    Feb 2003
    RAYMOND WA.
    So am i to understand with the deep pan and a oil filter change, drain and refill allison takes 10.6 quarts. Correct?
    ORDERED 1-15-03 ARRIVED 2-10-03= 03/2500HD/D/A/EXT.CAB LT/ LONG BOX/4X4/CARBON METALLIC/ONSTAR/ TTT CAMPER MIRRORS/WESTIN BOARDS WITH LITES/HUSKY FLOOR LINERS/PRO FIT FLAPS/ACCESS TONNO/LINEX BED RAILS/ FUMOTO OIL DRAIN VALVE,
    BEDRUG/BILSTEIN SHOCKS/ ISSPRO EGT GAUGE/RED LINE LUBE, BANKS EXHAUST BRAKE. GALAXY 929 CB/ WILSON 1000.KENNEDY LIFT PUMP.
  6. #26
    Dec 2005
    Klamath falls/keno Oregon
    Quote Originally Posted by DIESEL/VETTE View Post
    See post #7
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    427,300 miles and counting..
  7. #27
    Feb 2003
    RAYMOND WA.
    Thank you.
