Results 1 to 4 of 4
Thread: No power to ALDL
    Default No power to ALDL
    I am in the middle of a conversion on my '96 CK3500 from 7.4 gas to the LB7 duramax from an '03 2500hd. I have the engine mounted and "most" of the engine wires plugged in. I am at the point of filling fluids and seeing what happens when parts show up so I can get coolant in it. Something odd is going on in the fuel system, when I hooked up the batteries the injectors (maybe fuel pump?) started "buzzing" with the key off. It ran the battery down, after charging them up again I decided to try to pull codes to see if I could learn anything and the code reader will not power up, neither will the new fancy Edge CS tuner.
    Does anyone have any ideas what I forgot to plug in? Should I just start cranking when I get the Dex-cool in it to see what happens?
    Check the lighter fuse.
    On a new project like this where plumbing leaks are possible I prefer to fill with water first so if I have to pop something apart it's less of a mess.
    Got the system filled (no leaks) the hum/ buzz quits when I pull the fuse marked ECMI or the relay for the EDU. Engine turns over and fires for 1-2 seconds then dies. No message center lights at all.
    '94 C/K2500 5.7 5speed
    '96 C/K 3500 Crew LB7 /Allison conversion (in progress)
    The fire and die sounds like the anti theft. This will have to be nuked in the programming.
