Hi I need a quick answer is there a gasket between the exhaust manifold and the turbo and on the outlet to the exhaust pipe
I dont see any in book but just checking.
Thanks
Thanks
America Love it or Leave!
1999 Cheverolet K2500 Suburban 4X4 LT
Hybrid Diesel/Vegetable Oil conversion by me
In Memory of My Fallen FDNY Brothers
Never forget Never Forgive
On mine (not necessarily normal, being in a motorhome), there is a gasket between the turbo and the manifold (That is normal). On mine, the turbo exhaust dumps directly into flex pipe.
There is usually a metal gasket between the manifold and the turbo. No gasket at the down pipe. It's a v-band flange connection that doesn't need a gasket.
no gasket on mine...it was original equipment when I broke mine down.
95 Suburban 1500 Bone Stock Orig.
purchased at 103K from first owner
new alternator/autozone gold @104K
re-trannyed with shift kit @107.5K
new Bilsteins all around @ 127K
Kennedy exhaust @128k ..zoom!
new lift pump w/OPS bypass @ 130K
Kennedy FSD cooler @ 135K
New IP/Injectors/G-plugs @ 137k
Another autozone alternator and Optima Reds @ 150K
Another pump and injectors @157K
New chain and gears @157K
HO pump single therm setup @157K (will see what happens)
Head gasket or worse to be determined...164k
NEW AM General 6.5 installed and running well! @ 164K!!!!!
Come to think of it, they don't have a gasket from the factory. Every turbo shop that I've ever dealt with, though, has thrown in a metal gasket with a new or rebuilt turbo.
