Results 1 to 15 of 15
Thread: Drivetrain Temp Questions
    Sep 2006
    Brooker, FL
    Default Drivetrain Temp Questions
    I posted this in another thread, but I really transitioned to a different topic:
    Brief: Engine and tranny temps in the past few thousand miles have gone up as listed below. Neither is even approaching overtemp, but it's been an "item of interest". The engine used to run around 160° and the tranny 150°. Now it's 190°/180°.
    _____________________________________
    "Quasi-Epilogue: Because the transmission is operating normally, I replaced the thermostats (5-hour job because obstructions necessitated the removal of the entire housing to get at the 'stats).
    New 'stats were installed, and after 370 miles, the temps are still "what I'm not used to". But testing the old (OEM) 'stats revealed one was sticky, and in testing neither 180° stat cracked until over 195°.
    Coolant temp on straight-and-level runs around 190° with the new 'stats. Tranny temp is nailed around 180°. This is what I would expect in theory.
    I suspect that one of the OEM 'stats was stuck open, and only recently closed normally; prior "normal" temps were coolant <160°, tranny ~150°. These are cooler than I would have expected. Apparently, the stuck-open 'stat corrected itself, and in operating normally, increased the temps.
    Anyway, The tranny is due for change of fluid, which I'll do when I get home. I expect no difference in operating temps after. But at least I'll be able to collect any TC lockup residue for the Missy Good Wench Museum and Leftover Parts Emporium.
    Bottom line: I think the system is now working normally after not for a long period."
    Any comments would be appreciated, especially about causes for the change in operation that I've overlooked.
    Sep 2006
    Brooker, FL
    I should have added that temps for the first 5-7 miles of a cold start are in the 160°/150° range (I can see the twtch as the 'stats open), but then creep up to 190°/180°.
    So my guesses are:
    1. The old 'stats had one stuck open so temps didn't go to 190°/180° until it "unstuck".
    2. The torque converter clutches are shot, and the TC never locks up (It's always been hard to tell), increasing the heat (would an unlocked converter produce enough heat to cause this result?).
    Comments, or any other possibilities (a water pump impeller slipping on the shaft has been suggested, but after 2K miles, it should have failed by now)?
    It's difficult to say absolutely, but I suspect your torque converter never locking is at least the largest contributor. If there are other contributors, you can't diagnose properly until the TC issue is resolved. Unless something is blatantly obvious, your first course of action must be the TC. Your TC is not only open, but the friction from the TC attempting to lock up will, in fact, be capable of developing a lot of heat (not just from fluid friction) your system is not designed to manage. Heat is used energy, so your driving and trying to maintain a similar power level is using more energy (fuel), which in turn, produces more heat throughout the system, including the engine cooling system. All the while, the TC is adding wear materials to your transmission, which in turn, causes more wear. You have several cause-effect circles in progress, and none of them will lead to a positive result. Your TC is not "open", but is slipping while attempting to lock. This is a worst case scenario for all components involved.
    Sep 2006
    Brooker, FL
    Thanks for the reply, and your advice makes perfect sense; I wasn't sure how much the dying TC could contribute to heat.
    While the local rebuilder I use is excellent, he did use HD parts for the tranny, but the TC was from another supplier.
    I kind of suspected the advice would single out the TC; fortunately, after 5 road trips and 6K miles this year, I'll be able to park the coach for 6 weeks and get a Real HD TC installed.
    If the tranny is again ill, this round I'll have time to get a robust one from a specialty shop.
    Any suggestions on suppliers of HD trannies? And installers in the North Florida area?
    I'd prefer a package with an HD tranny with the Transgo kit installed, and a good TC (stall characteristics suitable for the 6.5L) to be done by someone experienced in these speciality products.
    Nov 2002
    Martinsville, IN
    Sun Coast Converters
    From what I have seen over the years, a converter that has lost the clutch will generally chew itelf up in fairly short order and things will start failing to work right real quick.
    Checking the pan for debris will tell the story.
    I think the coolant temp anomaly is just about what you are thinking, unless there is a gauge issue creeping into the picture.
    Swapping out the sending unit would possibly give a clue along these lines.
    Missy
    Sep 2006
    Brooker, FL
    The coolant and tranny gages are in harmony, so I think both are OK.
    Even if the TC is alright, I still want to replace it with one from Suncoast or BD Diesel Performance.
    I'm waiting to hear from Suncoast if they have the right TC; if they can, I may have them install that and rebuild the tranny with the TransGo kit and an aftermarket controller.... Apparently they don't install only converters.
    Sep 2006
    Brooker, FL
    Quote Originally Posted by ronniejoe View Post
    So far, Sun Coast has been a disappointment - the Guru who was supposed to call, didn't. More later if they show they want business.
    "90% of success is just showing up!" - Woody Allen
    Sep 2006
    Brooker, FL
    Suncoast came through! The Diesel Guy was road-testing all day yesterday. My coach is sked for the Deluxe Treatment Monday - New TC, billet, and transmission build.
    Sep 2006
    Brooker, FL
    Here's StaRV II at the Sun Coast Converters' Delux Spa (actually, Webb's Transmissions, where they had a lift [barely] big enough.) Britt and Nikki Webb actually also own Sun Coast; the transmission is over at Sun Coast where Ernie is rebuilding it as I post.
    Sep 2006
    Brooker, FL
    The Sun Coast transplant has been great! Engine RPM used to be 2600@55 mph, now it's 2200 RPM. I doubt that either of the prior TCs were actually locking up.
    With 500 miles on it, fuel economy seems to have increased 0.5 mpg (From 10.5 to 11.0).
    Temps are normal now.
    The transplant was well worth the investment.
    Nov 2002
    Martinsville, IN
    Cool. That's good to hear. I'm happy with the Suncoast products that I built into my transmission.
    Sep 2006
    Brooker, FL
    Got ~1k miles on the ensemble; fuel economy is definitely 11.5 mpg, up from 10.5 mpg...very pleased.
    BTW, while I was there, Ron Wolverton, who has been GM for Sun Coast Converters since it started, is now its owner, having bought it from the Webbs 6/9. Congrats, Ron!
    Sep 2006
    Brooker, FL
    The more I drive the coach with the Sun Coast thingies, the happier I am. Fuel economy has increased (over 1200 miles) from 10.5 to 11.5 mpg. Throttle/tranny response make it feel like an entirely different vehicle.
    This has been the perfect mate to the Peninsular Diesel/AMG engine installed 3.5 years ago.
    Sep 2006
    Brooker, FL
    With 2376 miles on the Sun Coast ensemble, fuel economy has increased to nearly 11.7 mpg from 10.5, and this includes about 700 miles of mountain driving.
