Results 1 to 4 of 4
Thread: Wheel Hub
Hybrid View
    Default Wheel Hub
    Hello, I don´t know if someone can help me with this:
    I have a 1995 Chevrolet Suburban Diesel 6,5 lts V8 LS K1500
    I have to replace the wheel hubs, but when I look for them in the web they come for 6 studs and mine is 8 studs.
    In the driver door says it was manufactured in Jenesville Winsconsin
    6/95
    Din: 1GNGK16F7SJ409630
    Type: MPV
    There are no Suburban Dealers here, so if someone can check for me and give me the correct part number to replace the Axle Bearing and Hub Assembly for my " 8 studs K1500 " suburban, will be apreciated.
    Regards,
    Daniel
    Daniel Patagonia
    6.5 Turbo Diesel Suburban K1500 1995
    "Catch and Release"
    Aug 2010
    Found a napa # for 8 stud bearing but its listed for a k2500 suburban:
    1995 Chevrolet Truck Suburban K2500 3/4 Ton 4WD
    Comments: w/ 8,600 lb. GVW;@Four Wheel Drive Hub Bearing@ Hub unit w/o ABS
    Per Car Qty: 2
    NAPA part # BRG BR930406
    $314.00 each
    don't know if that will help but thats what I found.
    Rock auto has a delco # listed with little information for the 95 K1500 part #FW243 that changes to the above # on napa interchange.
    delco #FW242 = LH hub
    delco #FW243 = RH hub
    both #'s change to the napa # posted above but much higher price.
    2005 Chev K3500 CCLB
    The Diesel K1500 suburbans carry 2500 running gear. The parts catalogs should reflect that, by GVW...
    Default Thank you
    Thanks for the info,
    Regards,
    Daniel
    Daniel Patagonia
    "Catch and Release"
