got a 93 3500 6.5 ,has a 5 speed, i want to put a 4l80 in it,has anyone done this and if so what all has to be changed. thanks
Easier than going the other way and having to add the clutch and associated hardware. I'd be tempted to go the route of a floor shift rather than trying to install one "on the tree" - but if you wanted that I'd swap in a column from a junkyard.
Where are you located? Could be interested in your 5-speed.
Diesel Page Member #2423
You'll also need a transmission controller and throttle position switch.
Thanks alot guys and yes floor shift it will be, I'm in shepherdsville,ky,any ideal where I can get the controller and tps I'll need
I'll admit that I'm not an automatic transmission person, so I didn't know. I had assumed since I see 4L80 and 4L80E mentioned that the 4L80 was a non-electronic version and you didn't have to mess with the TPS, controller, and all.
