Drilled/slotted rotors
I put new brakes on the front (rotors, pads, calipers, hoses) of my Tahoe around 10,000 miles ago. The rotors are warping again. I'm thinking of trying some higher quality drilled and slotted rotors, to see if they will last longer.
Any suggestions on where to buy, what kind to buy?
Thanks,
