My plastic 1993 headlights are getting pretty yellow and etched from time.
Can anyone advise if aftermarket suburban headlights will fit my truck?
Mike
Mike
Here is a picture of the lights I found locally.
http://www.thedieselpageforums.com/p...5585a813d5.jpg
Mine were very yellow with lots of crazing/swirls marks/whatever you want to call them. I used the 3M Headlight Restoration kit and they, honestly, came out looking like new. I was very impressed with what an hour of my time produced. My wife even made the comment that there was more light output. I followed it up with 303 protectant (and will continue to do so) to hopefully keep them looking that way. I think I paid about $15 for the kit on Amazon.
http://solutions.3m.com/wps/portal/3...cts/Headlight/
my friend mentioned using the same kit. I had no idea the product worked.
I have an opportunity to get the new aftermarket headlights at a great price, so was hoping they would fit.... it would be a gamble buying them without knowing.
I've used aftermarket headlight assemblies before - on our first 6.5 Project truck. They look great and worked fine, with the exception that one would fog internally after driving in the rain. The quality of materials isn't quite as good as OEM stuff, but being half the price can help... These came from Taiwan or some such. If given the choice today, I'd be tempted to use OEM.
The 3M product video shows an impressive result... for $15 you can't loose!
Thanks for the replies!
I saw an episode of "TRUCKS" and they used toothpaste with amazing results. Guess it makes a great buffing compound.
93 2500 - best truck I ever owned
Sold
98 GMC Sierra 1/2 ton 4X4 EC SB Dark Blue
3"turbo down to 4" back.
Remote PMD
Was S then F code now SSD ECM (used - it was cheap - not my first choice)
I thought I might try to do something like hand pumice cleaner myself... Toothpaste might be less harsh.
It doesn't hurt to give it a try, I did already take a very fine scratch pad used for sanding copper, and all the coarse bumps/scratches and yellow are gone.
It is fogged pretty good still, and will do a before and after from this point on.
Thanks for the suggestion.
I got my new lights for my 96 Suburban from Napa in Stoney Plain here in Alberta. I didn't think they were that expensive at the time.
Never had any trouble with them. I may still have the old lights sitting in the boxes from Napa. Do you want me to see if I can get part numbers off the boxes?
Hi Jim, sure..please send me the part numbers.
I have the NAPA warehouse a block away from me... I can always call to see what they are worth, if the toothpaste doesn't work out!
Cheers,
Mike
You may be able to find that episode of trucks on their web site. I don't know if they archieve or not. I believe they used the toothpaste on a 90* air die grinder with a buffing pad.
Sold
Remote PMD
Here is a pic of what the headlight looked like after a super fine sanding:
Here is 2 minutes of buffing with a blob of Crest Toothpaste:
Way better! When I have more time, the lights should be as good as new!
Good stuff!
Aluminum wheel polish also works wonders, Cream type usually 4 or 5 dollars for a tube. A little elbow grease and they should look like new.
01 Chevy HD - Gasser
85 K10 Suburbalanche with a Rebuilt 6.5 NA Diesel. Banks setup waiting on install
(Stolen-2008 and now proudly serving a Drug Cartel in Mexico)95 K2500 6.5LTD 5speed, 150,000 miles)
Good old crest! Prevents cavities and polishes headlights... who'd of thought? Did you use the whitening toothpaste or the regular?
On a more serious side, how did you apply it? I need to do this to my rig.
Sold
Remote PMD
It's simple, just smear a half inch of toothpaste on a buffing wheel, and rev it up and ensure you cover all areas of the plastic lamp.
I could have spent more time, but the lens cleared up so fast... I thought I'd save the effort for next time.
This was so effortless, I'll be doing it annually, before winter, when the days light is shorter and you find yourself using your headlights more.
This is one of those inexpensive fixes that surprised me. I planned on buying new headlights because mine were so weathered....how often can you salvage something so cheaply!
Cheers!
