Results 1 to 7 of 7
Thread: Hoping to get a VIN check pls
    Default Hoping to get a VIN check pls
    Looking at a 2007 GMC 1GTHK23D07F165352
    wondering if there anything I need to be aware of?
    Thanks for the help.
    New user...Jeff
    Dec 2004
    Maryland
    Default Here you go
    Vehicle Information
    VIN: 1GTHK23D07F165352 Model: TK25743-2007 GMC SIERRA SLT 2500 CREW CAB 4WD
    Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
    Order Type: 70 - RETAIL - STOCK
    Field Actions: 0 Open
    Required Field Actions Open field actions are highlighted
    Vehicle has no current record of required field actions.
    Branded Title
    *The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
    Vehicle has no current record of branded titles.
    Warranty Block
    Vehicle has no current record of warranty block.
    Service Information
    Type Number Description Posted Date
    SB G0000083901 Buick and GMC May/June Exclusive Service Offer 05/20/2011
    OnStar and XM Satellite Radio Information
    Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
    OnStar Equipped: Y OnStar Status: Inactive
    XM Equipped: Y XM Radio ID: U4TAQ0RM XM Status: Inactive
    OnStar Vehicle Diagnostics: N DMN Enabled: N
    Applicable Warranties Valid warranties are highlighted
    Valid Description Start Date Effective Odometer End Date End Odometer
    Diesel Engine Limited Warranty 03/16/2007 185 MI 03/16/2012 100,185 MI
    Powertrain Limited Warranty 03/16/2007 185 MI 03/16/2012 100,185 MI
    Emission Limited Warranty 03/16/2007 185 MI 03/16/2012 50,185 MI
    Bumper to Bumper Limited Warranty 03/16/2007 185 MI 03/16/2010 36,185 MI
    Corrosion Limited Warranty 03/16/2007 185 MI 03/16/2013 100,185 MI
    Service Contract
    Vehicle has no current record of service contracts.
    Transaction History View Details
    Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
    03/18/2009 177675 ZREG----Regular Vehicle Transaction K5387 - Transmission Fluid Auxiliary Cooler Inlet Hose Replacement 26,487 MI
    03/18/2009 177675 ZREG----Regular Vehicle Transaction K5389 - Transmission Fluid Cooler Lower Pipe Replacement 26,487 MI
    12/22/2008 175035 ZREG----Regular Vehicle Transaction J6298 - Exhaust Gas Recirculation Valve Motor Replacement 23,429 MI
    12/22/2008 175035 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 23,429 MI
    12/18/2008 174918 ZREG----Regular Vehicle Transaction J6353 - Module, Powertrain Control - Emissions Related Reprogramming 8/80 coverage 23,258 MI
    12/18/2008 174918 ZREG----Regular Vehicle Transaction B9622 - Lamp Assembly, Exterior - Auxiliary Lighting - Replace 23,258 MI
    12/18/2008 174918 ZREG----Regular Vehicle Transaction C3128 - Headlining Trim Panel Replacement 23,258 MI
    12/18/2008 174918 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 23,258 MI
    02/02/2007 309384 ZREG----Regular Vehicle Transaction B0140 - Bracket, Front License Plate Mounting - Replace 202 MI
    11/20/2006 A65352 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
    Dec 2004
    Maryland
    Default Heres the build sheet also
    Vehicle Information
    Vehicle Build
    Model: TK25743-2007 GMC SIERRA SLT 2500 CREW CAB 4WD Order Number: KMPTZR
    Gross Vehicle Weight: 4,177 Build Date: 11/20/2006
    Build Plant: F-
    Option Codes
    *IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
    1SZ - OPTION PACKAGE SAVINGS 3SB - SLE2 DECOR INCLUDES: *6-WAY PWR DR SEAT ADJUSTER *FLOOR CONSOLE W/STORAGE *ELECTRIC REAR WINDOW DEFOGGER *AUTO-DIMMING ISRV MIRROR WITH COMPASS & TEMP *AM/FM STEREO W/CD PLAYER *STEERING WHEEL-MOUNTED RADIO CONTROLS *BOSE PREMIUM SPEAKER SYSTEM *DEEP TINTED GLASS *LEATHER-WRAPPED STEERING WHEEL *CRUISE CONTROL *POWER LOCKS & WINDOWS *REMOTE KEYLESS ENTRY SYSTEM *POWER HEATED EXTERIOR BLACK MIRRORS *CHROME GRILLE *CHROME-STYLED STEEL WHEELS *BODYSIDE MOLDINGS *ELECTRONIC TRANSFER CASE
    41U - ONYX BLACK 69D - DARK PEWTER
    69I - DARK PEWTER INTERIOR TRIM 6GL - SPRING COMPTR SELECT FRT LH
    7GL - SPRING COMPTR SELECT FRT RH A31 - POWER WINDOWS
    A95 - FRONT RECLINING BUCKET SEATS W/POWER DRIVER SEAT ADJUSTER AG1 - POWER DRIVER SEAT ADJUSTER
    AJ1 - DEEP TINTED GLASS AM7 - FOLDING REAR SEAT
    AU0 - REMOTE KEYLESS ENTRY SYSTEM AU3 - POWER DOOR LOCKS
    B30 - FULL COLOR-KEYED CARPET W/MATS B32 - FRONT COLOR-KEYED FLOOR MATS
    B33 - REAR COLOR-KEYED FLOOR MATS B71 - WHEEL FLARES
    B85 - BRIGHT BODYSIDE MOLDINGS C49 - ELECTRIC REAR WINDOW DEFOGGER
    C6W - GVW RATING - 9,200 LBS CJ2 - DUAL ZONE AIR COND - AUTO
    CMD - ASSEMBLY PLANT - FLINT, MI D07 - FLOOR CONSOLE
    DF5 - AUTO-DIMMING ISRV MIRROR WITH COMPASS & TEMP DK7 - OVERHEAD CONSOLE
    DPN - PWR HTD EXT CAMPER MIRRORS W/ TURN SIGNAL & LWR CONVEX GLASS DT4 - SMOKER'S PACKAGE
    E63 - WIDESIDE BOX PICKUP BED FE9 - 50-STATE EMISSIONS
    FT2 - ARM TORS BAR SPRING ADJ FT3 - ARM TORS BAR SPRING ADJ
    G80 - H.D. RR AUTO LOCK DIFFERENTIAL GT4 - REAR AXLE, 3.73 RATIO
    HVY - IDEN 2 INCH BODY RAISE,HD MODEL JH6 - 4 WHEEL POWER DISC BRAKES, HD
    K05 - ENGINE BLOCK HEATER K34 - CRUISE CONTROL
    K47 - HIGH CAPACITY AIR CLEANER KC4 - ENGINE OIL COOLING SYSTEM
    KG3 - ALTERNATOR 145 AMP KNP - H.D. TRANSMISSION OIL COOLER
    KUP - THROTTLE CONTROL ELECTRONIC LBZ - DURAMAX 6.6L V8 TURBO DIESEL ENG - 360HP, 650LB-FT TORQUE
    MW7 - ALLISON 1000 6-SPEED AUTO TRANS NP1 - ELECTRONIC TRANSFER CASE
    NP5 - LEATHER-WRAPPED STEERING WHL NT9 - EMISSION SYSTEM FEDERAL, TIER 2 PHASE-OUT
    NZZ - OFF-ROAD SKID PLATE PKG P03 - CHROME WHEEL CENTER CAPS
    PDB - ONSTAR PLUS PACKAGE INCL: *ONSTAR SERVICE - INCLUDES 1 YEAR SAFE & SOUND PLAN *XM SATELLITE RADIO - SERVICE FEE EXTRA-1ST 3 MONTHS INCL. PDN - HEAVY DUTY POWER PACKAGE INCL: *DURAMAX 6.6L TURBO DIESEL V8 ENG-360HP, 650 LB-FT TORQUE *ALLISON 1000 6-SPD AUTO TRANS *H.D. RR AUTO LOCKING DIFF
    PY2 - CHROME PLATED STEEL WHEELS QIZ - LT245/75R16/E ALS BW TIRES
    R6C - CSV IDENTIFIER R6J - CUSTOMER DIALOGUE NETWORK
    R6K - TURN-BY-TURN NOT AVAILABLE R6P - PRICE LABEL PAINT CHARGE
    R8C - ******************************* ***** 2007 CLASSIC SIERRA ***** ******************************* R9N - LEATHER SEAT TRIM
    R9Z - POMS EXPEDITE-SOLD ORDERS SLM - STOCK ORDERS
    T96 - FRONT FOG LAMPS TFE - SALES INCENTIVE-COMMITMENT PLUS
    TQ3 - BATTERY 770 CCA (DUAL) U01 - ROOF MARKER LAMPS
    U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL. UB0 - AM/FM STEREO W/CD PLAYER (REPLACES STD/OPT RADIO)
    UE1 - ONSTAR SERVICE: INCLUDES 1 YEAR SAFE & SOUND PLAN UK3 - STEERING WHEEL RADIO CONTROLS
    UK6 - REAR SEAT AUDIO CONTROLS UQ7 - BOSE PREMIUM SPEAKER SYSTEM
    UY2 - WIRING PROVISIONS FOR CAMPER V22 - CHROME GRILLE SURROUND
    V73 - STATEMENT OF CERT. U.S. VB3 - CHROME STEP REAR BUMPER
    VG3 - CHROME FRONT BUMPER VR4 - WEIGHT DIST HITCH PLATFORM
    VXS - COMPLETE VEHICLE LABEL XHH - FRONT TIRE, ALL SEASON
    YD3 - BASE EQUIP FOR SCH GVW PLATE YD5 - FRONT SPRING - BASE EQUIPMENT
    YD6 - REAR SPRING - BASE EQUIPMENT YE9 - SLE/SLT DECOR
    YHH - REAR TIRE, ALL SEASON Z82 - H.D. TRAILERING EQUIPMENT PKG.
    Z85 - HANDLING/TRAILERING SUSP PKG Z88 - GMC TRUCK NAMEPLATE
    ZHH - LT245/75R16/E ALS BW TIRE-SPR ZY1 - SOLID PAINT
    Added Option Codes
    Vehicle has no current record of SAIO codes.
    Thanks GM tech
    What happens if I buy a truck with warranty, will the warranty go from build date (11/2006) or from the date shown on the VIN information (3/2007)?
    The truck is a repo that I'm looking at and I want to make sure I have warranty for possible problems.
    Jeff
    Quote Originally Posted by Jeff Huntington View Post
    Thanks GM tech
    Jeff
    3-16-2007. The OEM warranty is valid from the date of first retail sale, minus shop time (full days) and miles during warranty service. Being a repo doesn't matter, the warranty is just as valid. The only thing that can affect warranty claims is post-sale (first sale) modifications (tuner, emission system mod, etc.) or excessive abuse that can cause a denial for a specific claim. No one thing can "void" an entire warranty.
    GMCTech, Any way to get the service history and build sheet on the following VIN? Just about to pull the trigger on it and would like to know what's been done, what warranty remains and what's on it.
    Thanks!
    1GCHK63679F148611
    Never mind.
