I too run the Bilsteins front and rear on my truck. My wife also has them on her 2500 Suburban. I got both sets from John Kennedy a forum supporter...good guy and service. The shocks work well, just be advised that the rubber bushings are a wear item.
I have done some reading on this issue and it appears for whatever reason the shocks from the factory had a rod that is about 1 1/4" too short for the susoension travel. The aftermarket apparently followed that spec and all the shocks have this short rod. When the suspension is fully extended the shock gets stretched to the end of the rod length so the bushing picks up the impact, and wears. I think there is more to it that this but that is the jest of it. Some guys have installed an extension block on the bottom shock mount which seems to help. I don't know how far up the model chain that this is an issue.
Jeff
2013 Caprice PPV 6.0L
