I have a 6" HD lift (Superlift) with springs in front, 2 inch add-a-leaf and 4" blocks in the rear on my 83. Drive shafts are stock, but the kit requires dropping the transmission crossmember down and placing a 1 inch spacer between the front driveshaft and transfer case flange. It does require re-locating brake lines with new brackets, a new pitman arm and new steering arm.
This whole set up is bad for the frame and transfer case. Not to mention that the motor and transmission are tilted at all times. Chewed up many U joints, and this truck was driven pretty easily on the street only. The HD springs have no compliance, so its completely useless off road.
A 12 inch lift will require much more steering and brake modifications as well as drive shaft mods for extension and clearancing. Don't forget your anti-sway bar(s) too. If you do go for 12" of lift, there is no good way to keep the factory designed geometry. Go with a commercial designed cross over set up.
If you caused that much carnage already, 44" tires will shell out the axles on it quickly. If it has the original running gear, you have a 10 bolt front axle, and 9.5" semifloating rear 14 bolt.
