TheDieselPage.com Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > TDP Classified ad forum
TDP Classified ad forum Non-Commercial Member diesel related classified ads
Reply
Thread Tools Display Modes
  #11
Old 03-17-2010, 05:09 AM
Bobbie Martin's Avatar
Bobbie Martin Bobbie Martin is offline
DB2 Conversion Advocate
Pistons are sold!
__________________
Bobbie Martin
1995 Chevrolet Suburban 1500 6.5 TD 2WD- DB2 mechanical fuel injection
GEP Optimizer 6.53 Detroit Diesel Power
6.53L, GEP Block & Heads, .020 over, ARP studs, DB2 Inj. pump, GM8 Turbo w/TurboMaster
K47 Airbox with K&N filter, 3" mandrel bent exhaust, 2" Crossover, Mann ProVent
HO Water Pump, Hayden "Truck Fan" Clutch, 21" 9 blade Duramax Fan
No PMD, APP, CDR, optical sensor or vacuum pump!
Author of The DB2 Conversion Guide
Click Here to Email Me
  #12
Old 03-26-2010, 09:24 PM
Tough Guy's Avatar
Tough Guy Tough Guy is offline
C. Bigley
Quote:
Originally Posted by Bobbie Martin View Post
Pistons are sold!
Thanks for those!
Chris
__________________
1999 F-250 PowerStroke Crew Cab Short Box Lariat 4X4
Fumoto, Turbo-Master, MBRP 4", Billet Triple Disc TC, HD TransGo Tugger, AIS, Triple Pod, Autometer Phantoms, SPDiesel Overboost Eliminator, SCT Tuned By Tadd @ Elite Diesel Performance 75/100/125 and DP-Tuner 80 Econo PCM, Sirius Radio...
2006 Jeep Liberty CRD Sport 4X4
Stock for now...
My Gallery
  #13
Old 04-06-2010, 12:50 PM
The following parts are still available:
6.5 DB2 injection lines, good condition, $60 for the set
DS4 injection lines $25.00 set of 8
Aluminum front timing chain cover, $25
Steel back cover for water pump, $20
Crank dampers for electronic 6.5 Diesel engines, part 10154688. 1 very good $40, one good $20
2 rebuilt 6.5 fuel injectors $40.00
Factory Oil Cooler and lines from 1995 6.5 Diesel, lines were replaced with new lines from dealer in 2004, no leaks, complete set up, includes 4 new O rings & new spring clips. I can include block adapters if required, I have both sizes of block adapters so your choice. $45.00
Throttle Position Sensor for DB2 pump $50
Hummer hydraulic fan clutch, fan & lower 4 V belt pulleys and water pump & backplate , test run only $75 for all, parts are as new
1993 Turbo Diesel Exhaust manifolds, has one or two broken crossover studs, otherwise good cond. Can include crossover, its a little beat but usable. $50.00
1993 Turbo Intake manifold, upper & lower, NON EGR, $50.00
Used Autolite glow plugs. Set of 8, all ohm good, $25
Crank timing chain gear for electronic engines with reluctor cast on, like new, $15.00
Valve covers with or without CDR fitting $25 each
Flex plate for 6.5 with 4L80E $30.00
Cover for trans/flex plate $20.00
Exhaust heat shields $10 each
Turbo brace to intake manifold mount bolt $5.00 Turbo brace to upper intake $5.00
__________________
Bobbie Martin
  #14
Old 05-17-2010, 12:34 PM
Default Parts Update
6.5 Oil Pan, good used $25.00
Set of freeze plugs (new) $10
Engine bearings, for non oil squirter block, main & rods, test run only, PM for details
Installer for damper $25.00
1993 Turbo Diesel Exhaust manifolds, turbo side has one broken crossover stud, should be an easy fix, otherwise good cond. Can include crossover, its a little beat but usable. $50.00 for all
Valve cover with CDR fitting $25
Used CDR $20
heat shield for exhaust manifold under turbo $10
Starter brace $5.00, starter heat shield $10.00
All parts used unless stated otherwise.
__________________
Bobbie Martin
  #15
Old 03-03-2012, 02:27 PM
chestatee's Avatar
chestatee chestatee is offline
Dixie Ridge Runner
Default Parts for Sale
Sent pm
Michael
__________________
94 Chevy 6.5 Turbo HD 2500 Flat Bed-Dump-FOR SALE
BD Power - 4 inch exhaust and Downpipe, Towing chip
FSD cooler relocated and vented behind d/s battery
Jet Performance built 4L80E-HD deep pan
410 semi-float rear axle
Many other add ons.
93 Chevy k3500 HD- Single Rear Full Float Axle-Project
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
