Front spring clunking and slap
I have owned my medium duty (C5500) for three years now. I have always had a clunking from the front end when traveling at low speeds on a bumpy road or street or when transitioning from one street to another while turning right or left. It was very annoying. I posted on a Kodiak chassis site about my delema and after a some time got a reply that there is a fix. The fix is a set of Dalron blocks that are inserted between the two leaves near the front curls. What they do is eliminate the movement between the upper and lower curls at the forward spring mount.
The lower spring rear is allowed to slide on what appears to be a nylon flat bearing surface that is trapped between the rear upper curl and the lower spring end. I believe I'm getting some slapping from that in some conditions from the aft position. Still working on that. The block kit did eliminate 99% percent of the noise.
Just FYI
Denny
2018 GMC Denali HD 2500 L5P.
