Originally Posted by
Gene888
stabilizer bar bolt, spacer and bushings was missing from the drivers side. I picked up a replacement, but cant seem to compress the suspension enough to get enough threads to show on the bolt to nut it.
Are you sure the new one is the same length as the other one? If the truck is sitting level there should be no tension on either end of the sway bar.
