![Quote](images/misc/quote_icon.png)
Originally Posted by
Kennedy
Recurring theme as of late. Aftermarket sender (with sock) and hair pulling headaches ensue.
Aftermarket parts are often good, but more often inferior as has been the case here. Ask Casey (Arveetek) and I think there was one other that followed shortly after.
Just took a call yesterday from a guy with a 93 and new aftermarket sender. Truck went like 200 miles then shut off with filter full of air.
Yeah, it took me several months to figure out that it was the aftermarket "sock" that was squeezing down and shutting off fuel flow. I reinstalled the OEM "sock" and all has been good since.
I don't know if you can even find an OEM "sock" by itself. Like the original poster, the only option I found was a GM sending unit assembly with an insane price tag.
If you really do have a clogged OEM "sock", you should be able to take it off and clean it well with brake cleaner or some other solvent, and be back in good shape.
