Results 1 to 6 of 6
Thread: my heater doesnt heat
    Dec 2005
    Klamath falls/keno Oregon
    Default my heater doesnt heat
    blower motor works, a/c works, but no heat??
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Dec 2002
    Teton Valley, Idaho
    Does the engine seem like it is overheating?
    Does the upper radiator hose get hot? Does the lower radiator hose at least get very warm?
    Point being: Is your water pump moving any water?
    The first sign I had that my pump had spun loose from its drive gear was that the heater wasn't blowing any heat. The second sign was that the engine temp got WAYY hot. The third sign was that the coolant started blowing out the overflow tube. What should've clued me in to its not being a head gasket problem was the lack of residual pressure in the cooling system after the engine cooled down.
    then again, it could just be a bad heater hose valve...
    Dec 2005
    engine temp is fine...
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Nov 2004
    Blackie
    Default Heater dose'nt work.
    I had that problem on an 05 Chev 2500 HD Duramax and it was an easy fix but don't remember what the fix was. Try cycling through hot and cold.
    Loyal WI US
    Sounds like a stuck door?
    Dec 2005
    i found the problem, right under the glove box latch is a plug, my brand new border collie has toys down on the floor under the glove box..the plug was unplugged...got heat now!!
    Hummer wheels :^)
    dual lift pump
    Banks air intake
