How many miles on your injectors? What other filtration are you using? Lift pump?
Potentially anything that could cause the system to not deliver actual fuel rail pressures as commanded by the ECM can be to blame. I have personally never seen unloaded/high acceleration set this code.
In my cases its always towing heavy in the hills with heat as an exaggerating factor - i.e. HOT fuel.
