Well, I finally addressed something that has been bugging me for a while; the HID wiring and always looking for 12V power taps.
The HID's got upgraded to 12 Gauge wiring to ensure a good power supply. It's relayed for good power right from the battery.
I also needed to address being able to flick on the high beams without the HID lows going off. HID ballasts really don't like to be interrupted like that and can often die from the on/off spikes.
I though about the "4HI" modification, but that just seemed kind of clumsy with the relays already in the system. So, I ran a new wire and tapped the wire from the dash mounted headlight switch instead of the engine bay wiring that runs through the multifunction switch in the column. Now, the HID's come on with the dash rotary switch no matter what happens with the hi low selection. Does away with an extra relay too.
Now to address a place to mount all my relays and power taps. Where to collect them all up in one location rather than hidden all over the engine bay? A bit of metal work, a touch of welding and a spritz of Rustoleum black and I had a nice tidy spot:
Collects up all the relays, has a Fused 60 A 4 gauge 12 v supply, a ground terminal and room for more in the future. Lots of room and nice and tidy. It will probably get a fuse center as well.
I also took the time to mount the (gasp!) Ford DRl module:
You can just see the black box behind the battery. It was a quick clean solution to needing DRL's (law in Canada). It runs the bumper fogs on 1/2 power with ACC, full power when they are selected on, turns them off with low beams selected (but will stil run as fogs with the fog switch on) and turns them off the park brake is set.
While I was on a roll. I redid the my custom center console:
I incorporated a 200W inverter to run the various things we always seem to be dragging around with us (laptop cell phones, etc).
It started out as a cobra microport 200W inverter:
Had to slip in the cooling fan for the inverter heat sink:
I also closed up the iPod holder slot so I would a have a place to make a pen holder and attach the CB mic.
Coming along nicely....
Now that I've got it all sorted, I ordered my HID kit for the high beams. When it gets here, it will get a full 12 guage relayed wiring harness also.
As a side bonus, the relays remove all the heavy load from the interior light switches and places them all on the relay contacts. Simple matter to swap out a readily available relay instead of the expensive and hard to source GM switches....
