 1993 C1500 Suburban axle swap?
					I have a 1993 Suburban that I converted a while back to a 6.2L diesel.  I installed a 700R4 at the time, but it has always felt flimsy to me, and I have very little faith in it.  I have recently acquired a freshly rebuilt TH400 with only 1,300 miles on it from my friend.  He put it briefly in his '72 Chevelle with a 300 HP 350 crate engine in front of it.  He swapped it out for a Muncie 4 speed.  It was rebuilt by Pat's Transmissions in Delaware County PA, so I know it is properly done, because I used to deal with them all the time when I lived in the area.  My dilemma is this:
I need to put a taller axle ratio in the Suburban to use the TH-400 because right now I have 3.73 gears.  I have recently finished converting my 1996 Ford F-150 from 2wd to 4wd, so I have a good Ford 8.8 axle with 2.73 gears that I want to use.  It is stronger than the 8.5 corporate 10 bolt, plus it has a VSS built in to it that produces a VSS signal that is compatible with my Digital Ratio Adapter if I re-jumper it.  It is in excellent condition, and other than re-drilling the axle flanges and drums to the Chevy pattern, I think it would be a good fit.  What I don't know however is if the perches will match the Suburban's leaf springs or if they are spaced differently.  I wanted to see if anyone here could help with that.  I know that the TH-400 needs a tighter converter, and I know that I need a diesel governor and a VRV, but I have that covered.  I also know that some people think the 2.73 ratio is too tall, but mu 6.2 pulls 2nd gear on the 700R4 just fine from a near dead stop (from 5 mph at part throttle it accelerates pretty briskly) and the 700R4's 2nd gear with 3.73 axle gears is significantly taller than the TH400's 1st gear and a 2.73 axle, so I don't see it as a problem.  I should mention that I don't tow with the Suburban.
				1993 Suburban 2wd 6.2L Diesel Conversion "Andromeda":
3.73:1 gears, THM 700-R4 transmission, and
J-code 6.2L diesel from a 1984 C2500 Suburban
1996 2wd to 4wd converted Ford F-150 300ci Inline 6 "The Argo" 336,000 miles and climbing
1992 Caprice Wagon 5.0L V8 "Enterprise-D"
"Ah ha ha ha! I swear! Tractors is so dumb!" - Mater
"The Argo? That ridiculous pile of scrap metal!"
