TheDieselPage.com Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > 6.5L Turbo Diesel
6.5L Turbo Diesel 1992-00 6.5TD - Discussion forum for the 6.5L engine.
Reply
Thread Tools Display Modes
  #1
Old 07-09-2013, 05:55 PM
lars1 lars1 is offline
Enthusiast
Default Coolant in Oil?
I believe have another issue and welcome input. Our 1994 K2500 Suburban with about 150K miles had too much fluid in the oil pan (about 1-quart over the full line) and started to blow white smoke. The coolant was low and the car alarmed. It had sat for about 6-months when all of this was realized.
What to do considering coolant in the oil? The dealership "guessed" a failed head gasket and quoted $2,300 repair. What about internal damage due to the coolant?
The vehicle is good shape. I planning to loan it out as a school car for my son who just graduated.
Thanks in advance.
  #2
Old 07-09-2013, 07:50 PM
john8662's Avatar
john8662 john8662 is offline
modeRATOR
Sounds like a head gasket with the accompanied white smoke.
Usually not a biggie on a little coolant in the oil, fix the headgasket, drain oil, refill, shake it down. See how it goes.
J
__________________
1986 C10 SCLWB 6.2TD 3.73 700
1989 V20 SUB 6.2NA, 3.73 400
1994 G20 VAN 6.5NA, 3.42 60E
1996 K30 DRW 6.5TD 4.10 80E
  #3
Old 07-09-2013, 07:53 PM
joeq's Avatar
joeq joeq is offline
Running on M/T
X2 from above. I think that $2300 for a head gasket is a little extreme tho.
Even for both being changed.
__________________
Old habits, die hard.
  #4
Old 07-09-2013, 08:16 PM
Dvldog8793 Dvldog8793 is offline
Enthusiast
What type of antifreeze is in it? The orange stuff will actually mix with oil and form a goop that will stick to the inside of everything. if you don't get rid of it, it will eat your bearings. I would change the gaskets, refill, run it to op temp and then use an oil flush product and change the oil again then change that oil out after about 3-500 miles. Might be overkill but oil is cheap and bearings are expensive. If it was mine I would do that no mater what type antifreeze it was but for sure with the orange stuff.
Good luck
Hope this helps
__________________
2001 Chinook RV, V10 gas
1967 GTO, 1989 Honda Transalp
3 kids, 1 wife, 1 dog
  #5
Old 07-10-2013, 12:56 PM
rustyk's Avatar
rustyk rustyk is offline
Captain Doom
Dvldog is right - but ANY ethylene glycol will cause sludge.
I would flush the cooling system to completely remove the ethylene glycol. Then change the oil/filter and run the engine for a few minutes with the radiator cap off to flush the crud out, then change the oil/filter again, and run the engine again for a few minutes.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
