TheDieselPage.com Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > 6.2L Diesel
6.2L Diesel 1982-93 6.2L Diesel - Member access forum for any questions or information exchange related to the 6.2L engine.
Reply
Thread Tools Display Modes
  #1
Old 02-12-2014, 12:04 PM
TonyS. TonyS. is offline
Enthusiast
Default 1993 GMC 6.2L: Racor Filter Swap-in: return line?
I've got a 1993 GMC G3500 van with the 6.2L and am about to swap out the old leaking Stanadyne 80 with a Racor. My filter is mounted on the upper face of the engine towards the cabin. I've got the Stany filter and base off and now have 3 fuel lines. The in and out lines are obvious but what's the 3rd one for...return? What do you guys do with the return line? Thanks.
  #2
Old 02-12-2014, 12:35 PM
DmaxMaverick's Avatar
Administrator
The return is NOT associated with the fuel manager/filter. There should be 4 lines in/out of it: Bleed (top, external with a thumbscrew valve), fuel in, fuel out, and a water drain (lower, external with a thumbscrew valve). The van configuration may be different in orientation, but the fuel manager is the same.
__________________
  #3
Old 02-12-2014, 01:33 PM
Enthusiast
Quote:
Thanks, Dmax. I should have wrote my post better, and I apologize. What I was really asking was about the lower-most line on the bottom-left coming out that has a hose on it. I guess that's the water drain though there is no screw for it. The only screw I have on the housing is the top-most plastic one for the bleed port out the top-left side. Now I can get back to hopefully getting this done today. Thanks again.
  #4
Old 02-12-2014, 02:16 PM
Administrator
Yes, that is the water drain. The line attached should either disappear below and dump to atmosphere, or lead to another valve (not sure about the 93 van). The "normal" FM80's will have a plastic valve, like the top bleeder, on the side, at the same corner as the drain nipple. The 93 6.5's (FM100) have a drain hose leading to the front of the engine, with a needle valve located there. Yours may be a hybrid, of sorts. Follow the drain line, to be sure. Something stops the flow, either at the fuel manager, or along the line somewhere. Accessibility in the van engine compartment may have a play in it. GM considers water drain opening a regular maintenance step during normal periodic service, so accessibility would have been considered.
__________________
  #5
Old 02-17-2014, 09:57 AM
Enthusiast
Thanks again, Dmax! Now I gotta figure where in Hades I'm gonna fit this Racor 445. Nothin's ever easy.
  #6
Old 02-19-2014, 08:26 PM
Mikey von Mikey von is offline
Enthusiast
This is where I put my racor on my '89 Suburban:
__________________
'89 3/4 ton Suburban 4x4. 6.2L > Turbo400 > 4.10 open difs > 35" MTR's
  #7
Old 02-20-2014, 09:07 AM
Robyn's Avatar
Robyn Robyn is offline
Missy Good Wench ( Moderator)
Looks great.
__________________
(1) 95 Suburban 2500 4x4
(1) 2017 Mercedes C class
  #8
Old 02-20-2014, 10:40 PM
Yukon6.2 Yukon6.2 is offline
Enthusiast
Up here you would need to hang a piece of mudflap in front of it to keep it from being beat up by rocks.
__________________
  #9
Old 03-31-2014, 03:36 PM
Enthusiast
Mikey, nice job. You installed it after the e pump?
Quote:
I took a small sheet of metal I had and installed it in front of the filter to protect it from debris.
Actually, today I see I'm getting a leak from somewhere on the filter mount. I couldn't tell exactly where it's leaking but it's somewhere up top. Doesn't appear to be the primper bulb or its crimped ring. I tightened up the bleed screw. Only thing I can think is I used the regular JB Weld on the hose fitting threads when I screwed them in. I've just about had it with this whole fuel filter thing. The first one I installed leaked badly from the primer bulb's crimp ring. Got a replacement from the seller, installed it and was not leaking until now....3 weeks later. Nothing's easy.
PS, just thinking...I'm using a 2micron filter. Methinks it's too fine for a single filter setup.
  #10
Old 03-31-2014, 11:50 PM
Enthusiast
Quote:
Originally Posted by TonyS. View Post
Actually, today I see I'm getting a leak from somewhere on the filter mount. I couldn't tell exactly where it's leaking but it's somewhere up top. Doesn't appear to be the primper bulb or its crimped ring. I tightened up the bleed screw. Only thing I can think is I used the regular JB Weld on the hose fitting threads when I screwed them in. .
The best thing you can use for threads is hemp thread.I did over 150 pipe fittings on my boiler system,not one leak and i tested to 80 PSI.Even if you have a air leak as soon as any liquid gets to the hemp it swells and seals.
I did a comparison between Teflon tape,pipe dope, and hemp with pipe dope.The Teflon tape leaked the worst,just pipe dope second and the hemp pipe dope didn't leak.These tests were done on some tanks i was testing,each tank had 6 plugs,tried two of each on each tank.
It's a little more work to do it right,but rarely ever have to do it twice.
Thomas
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
