Well hot weather is gone and chain season is upon us if we want to tow out west, so I am done till spring (out west anyway). Still no P0087 made several more trips to Kalifornia, Utah, and Arizona.
2006 2500HD CCSB 4X4 RED LBZ
Spray-In Bed Liner, Air Bags
Custom Reese 20K slider FWH/Gooseneck hitch
265/75/16 Michelin LTX AT2's on PYO's
Kennedy tow tune
Kitty on a "warm shelf", K+N Drop-in filter
Amsoil in all places, Amsoil BMK-27 Bypass
KYB shocks (stock sucked)
Autometer Boost/Pyro gauges
EGR blocker and (Kennedy) finger stick
Transgo Jr. installed at 77325 miles
Kennedy Pump Rub plate installed, 98060 miles
Kennedy lift pump, reserve tank with transfer pump
2011 LML torque converter.
14.558 @ 91.03 Hypertech now?????
I will start with saying this is the best forum I have found in two years dealing with the same problems everyone else is.. Let me start with letting everyone know I purchased my 06, 4x4 crew 3500 new. I hauled 4000 to 10000 lbs coast to coast on random trips up to 75k miles. My normal travel was under 25 miles a day. In 2011 I started a new business in underground and started hauling 14K trailers 2 to 4 hour trips weekly, leaving my truck idle for 10 hours a day ect. Things were great until the August of 2012 while driving in 100+ temps on fresh blacktop... Engine code came on truck went into limp... After spending 2 months and 2000 dollars at 5 dealers getting 4 fuel filters on my 105K millage (out of warranty) truck I was pissed 4-5k to fix, no forums supported this as a solution that worked. I complained about the 250 degree fuel temps and was told by GM that it would have no bearing and was normal. I then discovered the fuel heater was stuck on and boiling my fuel for two months. Changed the entire fuel primer assembly and drove 65K last year no problem leaving the heater unplugged. (as mentioned here). The entire time the code comes on but only failed again this year. I have had my truck drop into limp mode as many as 15 times in 400 Midwest miles using only a 5 min restart on the highway.. Code does not clear but truck wants to run at 80 with a load... No rime, no reason...
My problems:
Heat outside 75 to 100+ Yes
Load causing failure Yes
Large hills with headwind Yes
Quick slow downs under load YES
tired of dealing with YES
I'm not clearing codes but once every few months but never have a performance issue until above conditions exist. I'm 100% stock, the Black Pearl works hard and gets stretched maintenance.. This is the best vehicle I have ever owned but I need a real solution to a heat/load related issue that does not require a engine rebuild.
220K with 7200 hrs and still breaks the tires loaded with 4 men, tools and trailer...
BTW: 50+ professional drivers with no CC and tuners. No problem from 100 to 400K on trucks....
I have not done anything to the cooling system other than have it flushed at 100K and at 200k. Just recently a friend recommended changing the thermostats because that worked for them.. I did do this and got about 20HP back but the truck runs at 200 to 210 with or without a load and has all along. It still breaks down though. I've be considering trying the fuel line. I also wonder if the Catilitic Converter is clogged. After idling for long periods my exhaust is blue and stinks like something rotten.
I forgot to mention that the 100K flush included a new radiator due to an accident. They replaced the radiator, Tran cooler and AC with GM parts.
Talk to Kennedy. You first need to make sure that actual keeps up with commanded fuel pressure. Your symptoms seem to mirror what mine were, if that is the case my injectors are worn and Kennedy sold me a program that has temporarily fixed the problem. I have about 60K on it since the fix, and I also get slightly better mileage towing which is a plus. Call Kennedy diesel and do as he recommends, John is a very straight up individual.
Kennedy tow tune
First of all, let me say thank you to the forum and its members for providing such great information that anyone with Google can find. My hat is off to you!
I've been battling a p0087 in an 06 GMC 3500 used to haul containerized trees around South-Central Texas. Tall and heavy loads, heat, head winds, and hills are all a part of 95% of the miles on this truck.
When the p0087 first showed up at 120k miles (18+ months ago), I immediately Googled it and after reading through numerous forums, I decided that ultimately the injectors are to blame, I skipped the rigamarole of debate and went ahead and had it done. A big chunk of change sure, but delivering is the most important aspect of our business and without our sole delivery truck, we weren't making any profits.
Fast-Forward to mile 155,237. A hot day in early June, heading from Columbus to Austin, a load no heavier and taller than any before. 30 minutes after leaving the farm and bam, code. Going up a hill, truck downshifted to 4th, (no cruise, tow/haul on) and hiccuped. A long miserable day of sitting on the side of the road, waiting for the code to auto clear. Anyway, by the time I got home, the code had thrown a grand total of 8 times (5 loaded, 3 empty). I hadn't seen this code in over 25k miles, and now 8 times in one day? What gives?
I read through this forum last week and have compiled a laundry list of things to do first. And was ready to get to work when...
My Schaeffer's rep called. This gentlemen truly has been there, wrenched on it, and lived to tell about it. So I ask him what is your take on a low fuel rail pressure code in a common rail diesel? With out a hesitation, "Your return lines are clogged."
Say what?!?!?!
"Well its simple sonny, your not flowing what is needed to keep the diesel fuel and associated parts cool. Your diesel is getting hot and your pump can't pump it. Its too thin."
My eyebrows are raised as I've read multiple people complaining about high diesel fuel temps. "Go on..."
"American diesel is junk these days. It grows algae and no one ever cleans their stock tanks. Everyone of those companies are selling junk diesel. He**, they're buying it as junk right off the tanker at the Gulf! There is algae growing in every stock tank in America, I don't care how cold it is."
So what is my fix?
"Shock your tank, Schaeffer's Fuel Shock #285. It'll kill that algae living in the plastic tank and in the aluminum lines. It'll clog your filter to hell but it'll work."
OK, how much?
$72 per gallon. One Gallon treats 4,000 Gallons of fuel.
Really? Give me a bottle.
Got me a turkey baster and shot 1 ounce of this stuff into each 20 gallon tank yesterday afternoon. Made a delivery this morning, no code, but the 3500 didn't quite have the gusto I was expecting. Maybe we need some more miles I thought. Got home, unhooked the truck and was authorized to joy ride the remaining 25 gallons of diesel in the tank away.
On the very first punch to get on to the highway, she heaved bad, AND THEN ROCKETED AWAY! This truck hasn't accelerated like that in a loooong time. That wasn't a down shift heave either, she was already winding up in a lower gear. This hesitation came right in the middle of two gears. When I lurched forward in my seat, I thought for sure I was going to get chewed out for destroying the truck...
Called my Schaeffer's rep. He explained to me that algae actually grows into the pores in the plastic and aluminum. You can't pressure wash that stuff out. Petroleum cleaners aren't terribly effective. I can't pronounce what is in this bottle but it definitely is some sort of organism killing stuff.
I'm off to finish burning those remaining 20 gallons and change my fuel filter. Next tank is getting Schaeffers #137. I'll post back after the next delivery. Until then...
1998 Ranger 2.5l, stock, 256k miles and never rebuilt!
1967 Mustang Coupe, 302, T-5, 9-inch, she goes just, having a hard time sticking...
2006 GMC 3500, stock, my current project...
2008 F-350 6.4L - Dead
1996 f-350 7.3, stock, sold at 350k miles
Schaeffer's Lubricants, I was leery, but the added horses and less maintenance are undeniable.
Begs the question: How many truck owners who have experienced the P0087 code use (or more specifically DON'T use) fuel additive/lubricant/conditioner/algaecide?
I use Power Service gray bottle religiously and (knock on wood) haven't had a problem. 190K miles on my '05.
A quality additive run consistently will prevent occurrence of microorganisms and keep the system clean and healthy. I'm an anti Power Service guy. FPPF Total power or in a pinch Stanadyne performance formula.
I seriously doubt that a chemical treatment of the fuel was necessary nor that it made any long term improvement, but I could be wrong.
What are you guys using to clear this code when you get it?
Any OBD-II scanner with code clearing capabilities (some are only designed to read the code and NOT clear it). I'm not sure how anyone else is performing the action, but I pull off the road, trun off the truck, connect the scanner, turn the key in the on position with the engine off and proceed to operate the scanner. Any parts store can sell you one. You can find them on internet, pretty much anywhere.
I picked up an Innova Model 3120b. It doesn't have the graphing function but I can read the freeze frame with and note some (not all) sensor outputs.
How much you spend is completely up to you.
An update from my previous post for anyone still working on this.
Did not have an opportunity to run the truck last week, no deliveries came up.
Used all the "old" diesel, installed a new fuel filter, drove around town a bit last week. Delivered a moderate load today, certainly not qualifying as "heavy". Headed to Austin on Hwy 71. 18 miles from the farm (about 60 on the fuel filter) and code thrown. A/C on, Cruise off, tow haul off, just driving normally, trying to keep above 70 mph, 81 degrees out, wind left to right 15-20 mph, moderate incline (nothing near 6%).
Modified my driving habits mid trip. I would accelerate down hill and refrain from depressing the accelerator pedal when headed up hill. Even pulled my foot out of the pedal on some of the steeper inclines.
Got to a section of 71 where there are some traffic signals. Used this opportunity for some full throttle acceleration. Couldn't get a code no matter how hard I mashed the GO! pedal. This is interesting to me. I'm getting up in the rpm range, I'm figuring my injectors are staying open a little longer, turbo is winding up, boost PSI is pretty up there, this motor is giving it everything it has, demanding higher fuel rail PSI. Why no code, especially with the injectors staying open longer dumping more fuel? Sure the CP3 is spinning faster, probably has a pretty good vacuum on the suction line (any hose pinching problems should be pretty obvious).
It got me thinking about it, this code is throwing under 2,000 rpm in high speed and loaded conditions in high gear.
Got to the delivery site without much opportunity for further testing. Oh well. Continued to ponder on the drive home from Austin and took the opportunity to test a little more.
I've narrowed it down to these conditions:
(1) Transmission in drive
(2) Any speed with the transmission in 6th gear (for me 52 mph or higher)
(3) A slight depressing of the go pedal while going up hill (even some not very steep) (pushing it to the floor makes the transmission down shift)
(4) A trailer connected (even an empty one)
With these conditions, this code throws every time.
So I popped it into manual (M on the dash) and selected 6 as my range to see what happens. Couldn't get the code to throw to save my life. I even turned around and went back to the last hill the code popped on. Still couldn't get it to do it.
So for now, I'm driving in Manual.
Further thoughts: Why does this code pop only at highway speeds with slight desired acceleration? Something to do with the transmission and engine communication? Anybody know how many sensors are in an Allison transmission? Why does the transmission, under full throttle acceleration, shift from 4th to 5th at 2700? Why is there a 6-700 rpm drop going to 5th? My foot is still in the pedal, I wanna stay up in the power band, not drop below it. Why, when the code throws, am at 92% (or more) calculated load? Where is this load measured or how is it figured? Why does my truck think it is so loaded with an empty trailer weight of 3,000? Is my transmission causing the increase in resistance? We've religiously maintained the axle bearings on the truck and trailer, they spin very easy by hand.
I'm beginning to think my problem isn't in the fuel system, its in the transmission. Something is telling my fuel system to go to max PSI with a slight depression of the accelerator pedal, WITHOUT down shifting the transmission, allowing more RPMs, boost PSI, etc.
Anyone know anything about an Allison 1000 transmission? I found this video:
http://www.youtube.com/watch?v=8xFwoTCInY8
(According to this video, Allison 1000 gear ratios are 3.10, 1.81, 1.41, 1, .71, .61, hence the big drop from 4th to 5th and the only slight drop from 5th to 6th.)
Do I have a failing torque converter? A faulty pressure sensor in the transmission somewhere? A leaking valve body? Is there anywhere I can plug my scanner into this thing to find out? (No there isn't, unless your trans is post 2009, when "prognostics" was added).
I remember older transmissions had a "dump" valve that was mechanically operated by the opening of the throttle. In higher gears, this valve would cause enough loss of fluid psi to down shift the transmission allowing the torque converter to spin faster and thus re-raise fluid psi while accelerating the vehicle. How is that accomplished these days with all this wiring harness connected to this transmission?
The chemical treatment has not cured your P0087 code correct?
Modified driving habits have helped you skirt around it correct?
I will stick with my original comments that this is fuel supply related:
A lift pump keeps the system under pressure happier and healthier
Secondary filtration keeps the fuel system happier and healthier
Regular use of a quality fuel treatment will often pay for itself with a small bump in economy and keeps the fuel system healthier and happier
Now as to the issue, heavy load high gear low RPM high ambient temps and very high fuel temps are the factors. The return flow is greater than expected due to injector wear. When operated in these conditions, the pump flow is insufficient to maintain demand. I have had some success with manipulation of the pump though ECM programming as IGO1320 has reported. Not 100% surefire, but pretty darn good.
I'm speaking for myself, but I had Lite Load, high gear, low RPM, moderate ambient temps (it was only 82 degrees yesterday). If a brand new set of injectors is wearing out after 25k miles, either the filter isn't doing its job or the CP3 has gotten weak (or the dealership installed crappy injectors, known to happen...). But others have posted here that replacing the CP3 didn't work either.
I'm not convinced a fuel supply problem, this code should be popping up under hard acceleration (mashed pedal) & loaded conditions if fuel supply was the issue.
Correct me if I'm reading the wrong information but the CP3 is mechanically powered off the cam chain. The only way the ECM can modify fuel pressures is with valve bodies in the CP3 and the FPRV.
What if I have a leaking intake system (think air entering the system AFTER the MAF)? Under high RPMs (more than 2k) vacuum could suck the leak closed, under low RPMs not enough vacuum to pull it closed. Is there an 02 sensor in the exhaust or something reporting exhaust conditions to the ECM? If so, it could be reporting excess 02 (compared to the MAF) and the ECM is trying to compensate by commanding more PSI than the pump is physically able to provide at under 2000 engine RPMs.
I'm still miffed that the transmission doesn't down shift out of 6 with any light/moderate depression of the accelerator pedal, this just doesn't seem normal to me (especially in "Tow/Haul" Mode). If this is truly the case, the transmission can take a lot more torque than the motor can provide (ie, at 65 mph and ~1600 rpm, the transmission is telling the motor "you aren't overloading me, no need to down shift" and the motor is struggling to put out the power to keep the vehicle/trailer going up a moderate incline).
http://www.dieselpowermag.com/featur...a_3500_review/
According to this article, the LBZ outputs 650 ft-lbs at 1,600 rpm. Times .61 (6th gear ratio) = 396.5 ft-lbs of torque at the back of the trans, times 3.73 rear end ratio = 1,478.95 torque @ 8.25" ring gear divided by 3.6 (tire diameter 29.75" divided by ring gear diameter) = 410.82 calculated torque at wheel/pavement contact of a brand new from the factory vehicle. Is that enough for approximately 10,600lb vehicle combo (~6600 vehicle (I have crew cab, "8 ft farm bed" + tool box and 2 20gal tanks) and 4,000 lb empty trailer) at highway speed up a moderate incline? Never mind the the power lost to heat, windage, alternator, a/c system, 150,000+ miles of wear on the engine, etc.
All that said, perhaps I have a clogged up catalytic converter? After 150,000 miles of dirty diesel (approximately calculated 18,750 gallons) causing excess hydrocarbons in my exhaust... Clogged cats can cause higher engine compartment temps. Anybody else noticed that the fuel supply lines are rather close to the drivers side exhaust manifold and the water separator/fuel filter sits right next to the passenger side exhaust manifold? And since the LBZ has EGR cooling, those hotter exhaust temps are flowing through the air cooler, raising temperatures entering the engine compartment. Now we have heat added all over the place due to a clogged CAT. Is this train of thought out of whack?
Has anyone with the catalytic converter delete experiencing the p0087?
So crawling around under the truck, I failed to find any sensors after the EGR components. So much for any 02 sensor readings going to the ECM
I also found that the EGR cooler utilizes the engine coolant to cool the exhaust gases, not the air cooler mounted on the front of the vehicle.
So now the cheapest option before me is a deleted catalytic converter. The idea being to prevent the EGR system from cycling higher than normal exhaust temp back into the engine compartment by getting that exhaust out the back of the truck.
I can't help but think that the close proximity of exhaust and fuel components is a contributing factor to this.
Most people posting with this issue use the vehicle for a significant amount of towing. They also seem to not have bunches of mods to their vehicles. Begs the questions:
Why aren't the modded exhaust system guys suffering a p0087 code?
Why aren't the people not towing anything suffering a p0087 code?
We've figured out the fuel treatment folks aren't having a p0087, go figure, they have cleaner burning fuel dumping less hydrocarbons into their catalytic converter and EGR system is taking the brunt of a clogged up exhaust pipe, its the only other direction for all that hot air to go.
If only GMC would have told me to upgrade the exhaust, use fuel treatment, and block off the EGR when we bought the truck.![]()
Thanks to all that have added their knowledge on this subject.
I have a 2007 GMC 3500 with 455,000 miles, completely stock and use the truck to deliver campers to all 48 lower states. I have been getting the dreaded 0087 code for the past year. I do have a Bully Dog connected but is not installed, only used to monitor temps and to clear codes.
I have a few questions I'd like to ask.
1 Has anyone found a true solution to this issue?
2 Kennedy I've noticed that it seems you believe it will be the injectors almost 100% of the time, but I have noticed 2 or 3 people have had their injectors replaced and it didn't solve the problem for them. What do you feel is happening to these trucks since they do have new injectors installed?
Thank in advance.
I can only go by what has worked for me in the cases that I have been directly involved with. Some that have done injectors and still had issues could have been overlooking fundamentals ie supply side restriction/lack of lift pump, or gotten poor quality injectors, or had a weak tired CP3. Hard to say.
It those cases we have successfully handled some with injectors and some with lift pump supply usually accompanied by tuning as well.
Just an update:
I have been dealing with 2 different LLY (technically LBZ) medium duty trucks battling P0087.
Truck #1 had a lift pump previously and we went through 2 unsuccessful rounds of tuning to fix his issues. Round 3 of tuning was sent last week.
Truck #2 had no lift pump but added my twin lift pump setup. This reduced his frequency of P0087's by 50% so we moved on to tuning. I based this tuning off what I had done for truck #1 even though I had not yet heard back.
Both owners called me today to report that the problem was solved in this weekend's operation. They both tried to throw what they could at their trucks and they just kept rolling. Truck #2 had a lot of black smoke prior to the tuning also which reportedly cleared up. Will keep in touch with them to monitor progress.
I have been doing my share of internet researching and besides fuel filter change and lift pump most other people make changes without a lot of evidentiary support. It seems people throw CP3's and injectors without really knowing if they are bad. I did some research on a professional mechanic database that accesses GM's info and it seems that they have a return rate test for the injectors that can at least assure an owner if the injectors are bad before spending 4K replacing them. The test for the CP3 were less precise more of a process of elimination but again I would try that before spending the 2K unless I just wanted to upgrade my components. They also had a test for the FPR on the CP3 but don't know how often they fail and the had a bottle test for the pressure relief valve on the fuel rail (forgot the name).
Since I now have a LBZ with the P0087 code I will do some more research and try to be systematic in replacing and hopefully from the cheaper side up instead of the other way around. One thing I can understand is the collapse hoses, fuel under vacuum (creating air bubbles) can both be cured by lift pump much less CP3 longevity which I believe the other manufacturers use in their diesels. I am surprised GM eliminated that component in their design esp since the previous design (6.5L) had lift pumps too.
I wish you luck in finding your issue and will watch for the resolution.
The issue is that the P0087 does not happen at idle, cranking, or low pressures where these tests are performed. It happens at high ambient and fuel temps and under heavy loads which is where the highest pressures are called for.
The 2001 LB7 tends to have chronic fuel pressure codes as well. I've done many hundreds of tunes for these. The DTC is P0093 large fuel leak detected. It seems that once the bug bites these trucks all the parts changing you can do will not cure it. I've been seeing the P0087 fixed with pump and injectors only to come back in much less time. Could be sub standard reman injectors or it could be skeletons remain in the closet. Either way I am hopeful to have a tuning related cure. It is highly likely that I will soon be doing an ECM for a customer who replaced pump and injectors 100k ago and now has the issue returning.
