2004 GMC 7Tf042. Isuzu 7.8L diesel engine. Oil in coolant. No coolant in oil. I'm a truck fleet mechanic and have three trucks with this problem. I have the engine oil cooler off and see no visible defects. If anyone has seen this problem and can lead me in a direction I would greatly appreciate it.
RECOMMEND TO LEAVE 14MM NUTS INTACT UNTIL REMOVAL OF HOUSING SO AS TO BE ABLE TO INSPECT COPPER GASKET MATING AREA B4 DIS-ASSEMBLY.
CHEV DEALER PARTS DEPT. DOES HAVE SCHEMATICS OF THIS ASSEMBLY & HAPPILY PRINTED THEM OUT 4 ME. ASSEMBLY COSTS $691.00 - BUT IT IS LIKELY YOU WILL ONLY NEED GASKETS & O-RINGS TO SOLVE PROBLEM. HAVE PICS OF ASSEMBLY REMOVAL STEPS ( DID NOT HAVE TO REMOVE FUEL PUMP) & BROKEN DOWN INTER-COOLER ASSEMBLY IF NECC. I'LL CHECK THIS POST EVERY FEW DAYS TO SEE IF YOU WANT ANY FURTHER INFO. 2004 CHEV T7500
