Thread: A/C Hose Assembly
    Aug 2001
    San Diego, CA, USA
    Default A/C Hose Assembly
    Hi, I'm in the tail end of rebuilding my A/C system and noticed some major differences with the replacement hose assemblies. My 84 has some rotted lines and after purchasing the new ones, I noticed that the high pressure to condenser line is too short and can't make the turn at the end of the radiator to condenser. I picked up an 85 set and while the high pressure mostly fits, the low pressure to the accumulator is way too long, almost not fitting in the engine compartment. The 84 lines look comparable to the originals, but has anyone experienced something like this? Suggestions?
    Thanks!
    85' Sub K-20 4x4 6.5 w/ cooling mods
    Phazer and Banks Turbo
    33" BFG's w/ Bilsteins Rebuilt 700R4 w/ all the upgrades
    Dec 2005
    Klamath falls/keno Oregon
    a decent parts store should be able to make them for you.
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Quote Originally Posted by spongebob View Post
    Ditto. In my old 6.2L C20, I had a local shop custom-make some A/C lines for me.
