Howdy
I have had a leaking fuel manager and by the time the trickle of fuel got down to the bottom it was nasty enough to look like oil. It came down right off the starter bolts. IMHO...if your starter has been loose without the nose bracket, I would take it off and give a good look. Also inspect the block area. When you put the NEW OEM(don't use any generic china crap, buy them in the GM package if you can) bolts in, make sure you torque them to spec and then after a few days of driving, retorque and check them often. As stated above, cheap insurance against a broken block.
Good luck!
2001 Chinook RV, V10 gas
1967 GTO, 1989 Honda Transalp
3 kids, 1 wife, 1 dog
