The 6.5L runs pretty hot. It doesn't take much towing to see the temp gauge climb quickly. In 1997, GM upgraded to dual thermostats and a high-flow water pump. That will help when towing and is a good swap to perform on pre-1997 vehicles.
Also, the stock GM fan clutch is terrible. It does not engage soon enough. I bent the tang on the coiled spring on the clutch so that it now engages as soon as the temp starts to rise. That one mod has helped tremendously on my 1995 6.5L.
