Results 1 to 7 of 7
Thread: Rocker arm retainer buttons
    May 2017
    North Carolina
    Default Rocker arm retainer buttons
    OK so, I was on here reading about rebuilding my heads and someone suggested that I replace these plastic rocker arm retainers ( thinking it was Robyn). Now who sells these as I am having a hard time finding them and was told they were cheap? I have only found them on EBay at 7.45 EACH. Which to me is high priced for plastic.
    Anyone know of a good place to purchase these?
    Again thank you all for the advice and help.
    Gary
    1995 Chevy 2500, 6.5L Diesel mostly stock 234,000 miles. Changed the water pump to HO WP, deleted the vacuum pump and added a mechanical wastegate controller made by me with info from others on the forum.
    RockAuto.com
    50₵ each.
    May 2017
    North Carolina
    Default Thank you
    Very much Missy!
    I listed the part # in the 6.2/6.5 tech forum under useful part numbers
    You are welcome
    AS mentioned Rock auto is cheaper MR1948 part number.
    When you install these use a round shaft of similar size that covers the button and tap into shaft carefully.
    Set the shaft in the cradles in the head and secure with the end bolts and then install buttons.
    Keeps things secured and easy to manage.
    Sep 2003
    Feeniks, Aridzona
    Wasn't someone making a steel replacement at one point?
