Results 1 to 6 of 6
Thread: 1999 Suburban with NV4500
    Default 1999 Suburban with NV4500
    This is not my rig, just saw it on Craigslist today. Looks like a really sweet rig. I just thought I would share to this DP community:
    https://joplin.craigslist.org/cto/d/...477720816.html
    That does look nice - a plus that it is a 3/4-ton model. Looks to be about 16 hours away from me, though.
    Diesel Page Member #2423
    Quote Originally Posted by trbankii View Post
    Make a vacation out of it! Come down and check it out, and we can have a mini DP meet and greet!
    It's in the same town as me if you want me to go check it out.
    Many years ago I sold an 86 Suburban 6.2L 2WD to a gentleman just outside of New York City. He took a bus to Missouri, I picked him up, he bought the Suburban, and then drove it home. Apparently, rust-free diesel Suburbans were in short supply up there....
    That they are...
    I’ve been toying with the idea of finding a K2500 pickup with a manual and swapping the Yukon body onto it.
    Probably easier to swap the drivetrain over, though, since the shortest GMT400 pickup is still 6" longer wheelbase than the Tahoe/Yukon? Either way, it'll be easier to have a complete donor vehicle to get all the bits and pieces you need. Cool project! The most reliable vehicle ever would be a mechanically-injected 6.5L with a manual tranny.
    I still like my automatic, though!
