Originally Posted by
More Power
I watched the TTY head bolts installed at the DMAX plant in Morraine, Ohio back in 2001 - they are all installed at the same time by a machine... Took maybe 30 seconds for each bank. I was thinking of that day while fiddling with the angle card setup for each bolt.
I remember that! I was there for the plant tour as well, and I thought that was the coolest machine ever.
